Question about Kenmore 22422 Top Load Washer
Series 70 kenmore elite washing machine
It is not spining the clothes correctly they are still really wet wet and the machine is not over loaded .
  • 4,889 Answers
Possible your belt is loose; you have to unscrew the back after disconnecting electrical connection from wall socket. If the belt "gives" more than half an inch, you have to loosen the motor bolts and push motor upwards, then tighten the bolts very well. Try spin only to check, before closing the behind. It shd spin very fast.
Let me know if it worked..
Posted on Oct 17, 2007
  • eagle338
    eagle338 Oct 17, 2007
    Another possibility is the tub spring fell out of the washer..
2 Suggested Answers
SOURCE:
  • 96 Answers
SOURCE: series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Posted on Mar 20, 2008
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
My kenmore 70 series washer is draining but clothes are still dripping wet
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 01, 2011 | Kenmore Washing Machines
I have a kenmore elite washing machine. it is not spining the clothes all the way. it is leaving the clothes soaking wet.what should i look at
Take the agitator apart by pulling off the softener cup and taking out the bolt, probably broken plastic DOGS. Ask your appliance parts guy for them.
Nov 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 70 series washer will not spin, clothes are too wet
Not a belt, this is only a sound deadening devise on the brake housing. Not really needed. Replace the coupler
Jan 03, 2009 | Kenmore 24032\24036 Top Load Washer
Not spinning
motor you hear is probably pump motor ..remove bottom cover remove acess port on pump and clean
Nov 16, 2008 | Kenmore Elite 45986 Front Load Washer
the agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Jul 19, 2008 | Kenmore 22422 Top Load Washer
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 22422 Top Load Washer Logo
211 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
