Question about Staples Furniture
Seat lowers when sit down - Staples Furniture
I HAVE A GMC 2005 SEIRRA TRUCK .HOW CAN I LOWER THE BACK SIT ?I DONT HAVE A MANUEL.COULD YOU HELP ME?
i have a sierra 2500hd basic truck and the front center does not fdold down and the rear bench only the seat lifts up by pulling the strap under front edge of seat down ward hard and lift the seat up the back rest does not fold down
Aug 23, 2017 | GMC Cars & Trucks
How do I remove the lower rear seat
Hi there on a 3 series there are two heavy duty clips that hold the seat down and they are located along the front edge of the seat right in the centre of where the left and right rear passengers would sit, on these two locations grab under the seat and pull upwards fairly hard and the front of the seat will pop up, once the front is up then scoop the seat out. hope this helps
Feb 27, 2015 | 2004 BMW 3 Series
How do I remove rear seat in 99 escort 4 dr
There is usually two ways they have seats in. Press down hard on a rear corner of lower portion (part you sit on) of seat and look and feel for a bolt at rear of seat. Would be one on each side. The other way (if no bolts) is you have to get in car and use your knee and push back hard on lower part of seat while lifting front edge. There is a portion of seat frame that hooks in under front edge of seat and you must push in hard to get it to back away from tab in floor that it is hooked into. Push in and lift up on both sides and it should pop out. Have seen some cars that have small push / pull tab at front edge of lower portion - but that is usually on Asian cars.
Feb 23, 2015 | 1999 Ford Escort
How do I change the battery in royal star
Most Royal Stars (since you gave no year or which Royal Star model you have) have the battery located under the seat and most Royal Stars use the key lock located on the lower left side (as you sit on the bike) near the seat to unlock the seat and lift off. Pushing down on the seat to turn the key in the seat lock makes it easier to turn the key.The battery usually has just a rubber strap to hold it in place.
Feb 18, 2015 | Motorcycles
Rear remove seats
On the lower half seat right where a person sits, Push down and forward at the same time to unlock each side
Apr 06, 2014 | 1984 Buick Riviera
How much do seats (towers) for sit-down hydrofoil cost?
Seats (towers) for sit-down hydrofoil cost $250 and up. You can purchase them at these websites: http://skyski.com/store/seat-towers.html and http://www.airchair.com/Products/seat.htm
Feb 06, 2013 | Water Sport
On a '97 jeep grand cherokee limited, do the back seats lay forward? If so, how do you put them down? Thank you.
On each side of the back seat (the part you sit on), there is a loop. Pull this up, and the seat cushion will swivel up towards the front seat back. Visible at the lower corner of the seat back, is a lever that tou can pull up ( the earlier versions needed to be pushed down or back). The seat back will then fold /down/forward. The headrest must be removed so that the seat back can fold flat. The headreat can be removed by turnibg the small knob at the base of one of the head rest shafts. There is a small arrow indicating the direction of rotation to accomplish this.
May 09, 2011 | 1997 Jeep Grand Cherokee
Seat height seems high according to specs ; vtx1100c2 2004
you could try a little bit smaller rear tire. cheaper than the shocks maybe
Jun 07, 2009 | 2004 Honda VT 1100 C2 Shadow Sabre
03 durango cant get third ro seat to lay down
These can be tricky but here is the FixYa. Raise the CUSHION (where you sit on) of the back seat, it will swing up and out, then down. Now you can lower the back of the seat assembly. Salesmen really should show customers this, but rarely do. Have Fun!!!
Nov 07, 2008 | 2003 Dodge Durango
Furniture Logo
138 people viewed this question
Top Staples Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Staples Furniture Expert? Answer questions, earn points and help others
