Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell air conditioner wont turn on. says following schedule
When i manually try to put my air conditioner on, meaning I hit the down button to lower the temp, it says "following schedule" so it will not do what i say. I went into the schedule page and deleted all the scheduled times it had on it, but it is still saying that it is following a schedule.
Is there a way that I can reset this or something so i can manually change the temp but hitting the up or down arrow on my screen?
  • courtlcronin May 20, 2009
    Thanks I have done that but i do not see the reset button....
  • 148 Answers
Take the front face plate off wall it may have a reset button behind it
Posted on May 19, 2009
  • Jason vangel May 26, 2009
    DICONNECT THE C TERMINAL AND REMOVE THE BATTERY LET ME KNOW
Thermostat is following a schedule when none is set
Your Lennox thermostat could be defective, but it may have been programmed by some inadvertent button pushing. The thermostat also has certain default settings such as a low limit that will trigger heating if the indoor temperature becomes too low (to prevent freezing of pipes).
Feb 09, 2014 | Heating & Cooling
RTH2510B thermostat Honeywell How do we adjust the temperature to cool it down. We are in Florida and it is 89 in the house. How can we set it easily for 70 all day and night?
Hi, You should be able to just push the down arrow button...
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Jul 24, 2011 | Honeywell Heating & Cooling
I have a honeywell rth2510 thermastate how can i change from celcious to farenheit
here is a download for the manual on page 12 and 13 in English.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2380ES.pdf
Press the up and down button simultaneously from a few second till display changes and then on #1 set it to option 1 and that show be C.
Feb 21, 2011 | Honeywell Programmable Thermostat Heater
I have just moved home and we have a Honeywell CM61 Prog.Thermostat but no operating instructions.Can you help?
Push run program for a preset schedule, once in the schedule you can change times via up/down temp buttons, push next to set next schedule period and so on. Otherwise push hold temp or hold to overide the program and run as a regular stat, for more info 1800 honeywell or Google support.
Nov 01, 2010 | Heating & Cooling
Flashing star on honeywell air controller, and air wont work
heatman101
Sep 27, 2010 | Heating & Cooling
I don't know what the hold temp means on my honeywell thermostat
1. You didn't indicate what model of thermostat you have.
2. Hold function on a thermostat with scheduling would mean to hold it at the manual setpoint indefinitely, in other words not following the schedule. 3. I assume the temps you're trying to achieve are C If you have a heat-off-cool switch, I assume it is on the cool position. Most of the honneywell thermostats with a digital display, will indicate a little flame icon when the thermostat is calling for heat, and a littel asterik (snowflake) when calling for cooling. If you don't see the asterik, then you may have a thermostat problem. Have you checked to see if your furnace (air handler) is running? Have you checked to see if your condensing unit outside is running? If they are running, then you have a refrigeration issue.
Jul 07, 2010 | Honeywell Heat/Cool Thermostat
Honeywell T8112 Air Conditioner Will Not Cool, But Blower Works
make sure the system switch is in the cool position, then press run program button and allow a couple of minutes for system to cycle on, if it doesn't come on press the button for lowering the set point, set it to 72 degrees and then press the hold temperature key.
May 27, 2009 | Honeywell ER150B Air Conditioner
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
We have a Honeywell A/C (we believe it's a focus pro 6000) that is not working properly. The A/C unit itself is running but the vents inside the house are not cooling. We think it's a problem with the...
the honeywell is just a thermostat.my guess is the capacitor went out in the condenser when you lost power.turn the temp down on the thermostat and hit the hold button.....if it does not cool,call a service tech.good luck!
Sep 24, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
1,430 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
