Question about GE Kitchen Ranges
GE Range Model GRCR3630ZWW-2 DOOR error code on range display
Door error code
jyackle5
  • 8197 Answers
SOURCE: Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
Posted on Jan 07, 2009
  • 530 Answers
SOURCE: Error Code F@ on GE XL$$ Range
usually f02 means you have a shorted keypad. does it randomly beep at you if so this is a symptom. you need to replace your keypad
Posted on May 29, 2009
localwonder
  • 6784 Answers
SOURCE: range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Posted on Nov 08, 2009
SOURCE: GE Range Model GRCR3825ZWW-1 DOOR error code on range display
The door latched Micro-switch is not working or is dirty.
Remove the back panel, in the middle of the back there will be a metal arm that moves in and out when self cleaning latch is closed and opened. This arm pushes two or more Micro-Switches in the back, they are dirty or not working and need replacing.
Posted on Jan 12, 2010
  • 61 Answers
SOURCE: Electric range displays bake probe
if you need a parts check out appliance parts solutions
Posted on Feb 10, 2010
Getting a PF7 code with beeping on my stove. Reset breaker, didn't fix it. Any help would be appreciated.
GE oven error code "F7" and how to fix it ' AskGene.com
www.askgene.com/.../oven...codes/ge-oven-error-code-f7-and-how-to-fi...
Jun 23, 2007 - The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic ... We have a GE Spectra Oven - GAS - we keep getting F7 errorcodes and the oven will not heat. ... In my case it was the keypad.
Why is my GE Range model number JBP80SM2SS making ...
www.shopyourway.com > Manage My Life > Questions
Apr 6, 2010 - Get shopping advice from experts, friends and the community! I was boiling water on back burner of ceramic stove top GE range Model ... When anyappliance picks up an error code or starts beeping the problem that caused it ...
Jan 08, 2016 | GE Profile 30" Self-Cleaning Slide-In...
GE RANGE DOOR LOCKED ON DISPLAY WITH FC ERROR
You might want to ask GE. They want customer satisfaction.
Nov 29, 2013 | Washing Machines
Oven will not work.
This is what GE recommends for your oven:
“F—and a number or On models with a door latch, • The latch may have been moved, even if only slightly,
letter” flash in the display if a function error code appears from the locked position. Make sure the latch is moved
during the self-cleaning cycle, to the right as far as it will go.
check the oven door latch.
You have a function error code. • Touch the Clear/Off pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the range for 5 minutes
and then reconnect power. If the function error
code repeats, call for service.
May 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Hi. Stupid question for you, but I just can't find my manual! The model # of my GE self cleaning range is GRCR3630ZWW-2 if this helps. I need to clean my range today and how exactly do I do that using...
Hi, check this web page, which is a PDF file of GE oven manuals. It appears that you have to close a latch on the door to start the self cleaning.
http://www.abt.com/images/products/BDP%20images/ge_jbp24_man.pdf
Hope this helps!
Apr 25, 2010 | GE JBP68 CleanDesign Electric Kitchen...
GE spectra JBP66 electric oven that displays the F2
f 2 code states that oven has exccded 590 deg w/door in unlocked position or 990 f in locked . either the themp prop is bad or the relay in the EOC ( clock ) is welded closed . I would replace the prob first ( less expensive ) then the clock if needed .. **** ..
Dec 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
May 29, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Ge Profile model jgb900 has error codes & oven doesn't work
Hi, this is a lock switch malfunction and you may need to replace this.Check the wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Mar 06, 2009 | GE Profile JGB900 Gas Kitchen Range
Code fpf flashes on clock on ge elec stove model jbp26gs1ad
I am sorry, but there is no such error code mentioned among the GE Fault codes.Or this could possibly be because of a faulty display.The display can be replaced on a call.
Else the possible error code similar to this one is "PF" which refers to power failure but generally not related to kitchen range.
Please do check if there is a display change of the error code and post your valuable comments. would be glad to help.Good luck.
Jan 16, 2009 | GE JSP26 Electric Kitchen Range
Nov 05, 2008 | Kitchen Ranges
Error code
All the information I could find on GE ranges indicate that an F-7 error indicates a problem with either the Electronic Range Control (ERC) keypad having a stuck key, or the ERC itself being defective. You can unplug the ribbon cable on the ERC and wait at least 32 seconds before plugging it back in to see if the problem clears. If the problem persists you will have to replace the ERC. Make sure you UNPLUG the range and/or turn off the main breaker to it BEFORE servicing. Remove the back panel of the range to access the ERC. If you cannot get the fault to clear and wish to replace the ERC, post back with comments as to your model number (usually located on the frame of oven door opening or lower drawer opening) and I will research to find a part number for you. Keep in mind, most ERCs do not come with the overlay (plastic piece with the number and keypad displays). I would advise you to replace both if you decide to repair the range. i hope this info helps you.
Nov 06, 2007 | Kitchen Ranges
Kitchen Ranges Logo
77 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
