Question about Dryers
Drcs 76 beko squeaking noise - Dryers
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Beko DRCS 68W tumble dryers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Aug 28, 2011
kachbibi1
  • 979 Answers
SOURCE: my beko drcs 76b tumble dryer isnt heating up
First turn of the breaker, then back on. Check the wiring from the plug at the receptacle to the back if the dryer. You should find your problem there. Then next is the element. See if the wiring is ok to the element. Next visually check the element for
Posted on Mar 10, 2013
Beko Dryer model DRCS 68W
First unplug power cord for a min and see if it will reset cycle
Jan 09, 2018 | Dryers
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
Beko drcs 68 w cond dryer 3 yrs old an electrical trip sound followed by a burning wire smell
It could very possibly be that some of the lint has migrated thru the cracks of the lint "tunnels" and settled down around the heating element. Danger Will Robinson! Learn how to remove the front cover/door or back side and inspect for loose lint. It is normally lots more accumulated than you could imagine.
Nov 07, 2014 | Dryers
Beko dryer
i have had this problem and its usually the pc board is faulty
Mar 28, 2014 | Dryers
Got a beko condenser dryer drcs 76w drys clothes but water doesn't go into draw comes out under machine
Sounds like the hose has come loose at the drawer and so it's just pushing water directly down on to the floor, check your owners manual to see how to access the water resiviour.
Dec 05, 2013 | Dryers
My beko drcs 76b tumble dryer isnt heating up
Mar 10, 2013 | Dryers
My Frigidaire Gallery dryer squeaks and leaves brown crescent burn marks on our laundry items.
If you live in Pasadena, CA and you need a Dryer repair service our professional technicians will perfectly repair your dryer as fast as possible. All you need to do is to call at (626) 460-0903 or visit our website http://www.appliancerepairspasadena.com .
Dryer repair Pasadena CA Bosch LG Electronics Amana Beko
Sep 02, 2017 | Frigidaire Gallery Series GLHS269ZDB 36"...
Beko dryer, drum is turning and heating up fine but making a loud scrapping/rubbing noise, what could it be?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Dryers
Beko DRCS 68W tumble dryers drum is not rotating (spinning), heating, drying is working
heatman101
Aug 27, 2011 | Dryers
Beko drcs 68w the sensor stops the drying process before the clothes are dry
you have a bad sensor...try just using timed dry
Jan 17, 2010 | Dryers
Dryers Logo
Top Dryers Experts
