Question about Refrigerators
Frost in freezer compartment
Amana bottom freezer.  frost build up blocking recirculation vents in back of freezing compartment. the freezer compartment is 0 degs the refrigerator compartment is too warm. the refridgerant fins were cloged with dust which i cleaned.
  • Anonymous Mar 23, 2014
    ice layer formed at rear of freezer compartment on an Amana Distinction model
  • 473 Answers
It is possible to get this build up in the return vents.  Check seals for any possiblilty of warm air getting into the fridge.  Warm air getting in will cause this.  For now use a hair dryer or some hot water to clear the vents.  Let me know what you find.  Would appreciate a solved rating for expert advice.
Posted on Oct 18, 2007
  • _vid Sep 15, 2010
    We have an Amana French door bottom freezer having this same problem. We had moved the contents of the fridge to coolers and found this post. So we pulled the freezer baskets out, unplugged it and used the blowdryer trick. It worked great! My wife cleared the vents and I dried up all the water.
    Thansk!!!
SOURCE:
My fridg and freezer is cold but not could enough the freezer wont keep food frozen. there is no ice build up, I replaced the defrost timer, and I cleaned the fan in the back what else could it be please...
Hello Nicole,
Their are a few things that couldbe causing your refrig.troubles.
1) their is ice build up in the return air vents that is not allowing air to flow correctly
you can see the air vents under the crispers in the ref.floor and can see if they
blocked with ice.
2) the freezer fan is bad and not circulating cold air into and out of the ref.
3) In addation to the defrost timer,perhaps the deforst heater and defrost thermostat are bad and frost is building up in the freezer,Do ya see frost
build up in the freezer??
GENE
Sep 21, 2011 | Amana BCI21V1C Bottom Freezer Refrigerator
I have a top freezer/bottom refrigerator-6months old-no icemaker hooked up. There is water dripping continuously into the refrigerator compartment-some of it freezes and the rest accumulates in the...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 17, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
I have power but my Amana is not cooling and am trying to pinpoint the problem....
When you slide the freezer baskets out do you see frost on the vent holes cut into the back panel in the bottom of the freezer? If so your refridgerator isn't defrosting and the ice build up is blocking the cold air from being circulated.
Oct 28, 2010 | Amana ARB9058C Bottom Freezer Refrigerator
Freezer is cold but not freezing, refrigerator is not cold
your defroster heating element behind the frosted panel is either open(bad) or the defrost heater control in the refrigerator compartment is defective
Jul 13, 2010 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Frost is building up in bottom freezer. Amana ABB2224DEW
I have this problem as well, only nobody is leaving anything open. The defroster is defective of these things and the duct between the fridge and freezer gets frozen over and the cold air can't get in the fridge, so the freezer keeps working until it's blue in the face.
Apr 19, 2010 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Frost buildup
you need to check the defrost circuit and make sure the heater is working and the unit goes into the defrost mode.
also check and make sure the temp sensor is good
Apr 13, 2010 | Amana ABB1927DE Bottom Freezer...
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 | Dishwashers
Freezer side not freezing
It is possibly your defrost element which is not working causing a build up of ice and reduced airflow through the freezer compartment. This is located behind a cover in the freezer compartment. It is best to change both the element as well as the defrost limiting thermodisc which is attached to the fins of the evaporator.
Mar 04, 2009 | Amana SXD524VW Side by Side Refrigerator
Refridge not cooling
freezer side is working good but cooling side is not cool
Sep 24, 2008 | Amana ARB8057CSR Bottom Freezer...
Refrigerators Logo
493 people viewed this question
Top Refrigerators Experts
Sal De
Marvin
Marvin
