Question about Air Tools & Compressors
How to set up the aeolian pixie airbrush compressor
How to set it up
2 Suggested Answers
  • 1212 Answers
SOURCE: How do I connect a badger airbrush hose to a Airbrush Depot TC20T compressor?
Airbrush Depot compressor should be a 1.4NPT which is the most common- Badger makes an adapter for this size to their hose fitting. That fitting should be available from many sources. Badger did/does use a couple of sizes so make sure you know which model of brush you have.
http://badgerairbrush.com/Acessories_4.asp is the piece.it is at the bottom of the page.
If nothing else, it should be available through Walthers http://www.walthers.com
Posted on Feb 15, 2012
What oil does an aztec ac1 compressor use?
It's a re-branded Werther Sil-Air compressor (15EAC) & uses Sincom 32/e oil that is supplied for Sil-Air compressors.
Jun 01, 2013 | Testors AZTEK A470 Airbrush Set A4702W /...
Salon tc 60 airbrush compressor won't build up over 17 lbs pressure.
Either the pressure switch needs adjusted or the compressor needs rebuilt.
Jul 27, 2012 | Hobbypet TC60 Super Quiet High Performance...
Feb 14, 2012 | Master Heaters Air Tools & Compressors
Need manual...part description to re build airbrush
Try this link!:
http://www.tcpglobal.com/airbrushdepot/itemdetail.aspx?itemno=MAS+P70-MAJOR
G77 is a set which includes G76 Airbrush!
These store sells the major rebuilt parts kit for the G76!
Hope this 'push' helps!
Oct 12, 2011 | Master Heaters Model G77 Airbrushing...
My daughter bought a master airbrush spray tanning system - g70 - with no instruction manual. air is coming out but no tanning solution - any assistance would be greatly appreciated
I got the exact same kit as a Christmas gift (I am a cake decorator). I have asked the supplier how to fix this problem, but they only told me to google airbrush videos. I'm not sure how to connect all the hoses to the compressor and the external paint cup. Been struggling for weeks to find info online. I also have a G34 and that works fine (but it only holds a miniscule amount of paint). Good luck, hope you manage to get an answer.
Jan 16, 2011 | Master Heaters Master Airbrush Model G75...
Is there an instruction manual for the Master Airbrush Model S68?
i am not getting the paint to spray from the paint cup please help
Dec 15, 2010 | Master Heaters Master Airbrush Model G75...
Does this dental air compressor have a oil pressure safety switch?if so, where is it located? can I find a wiring diagram
Air compressors are designed to operate many different tools. The value of a commercial air compressor is many times greater than the purchase price because of the amount of work a single air compressor can perform. Dental air compressors are some of the most reliable because of the high-quality air they supply and precision tools they operate. As a result, dental air compressors can be adapted for a number of different tasks, including artistic air brush painting
1.Disconnect the air compressor from the dental tool air supply. Pressure and air supply rate-of-flow settings are different for air brush painting than for air delivery for dental tools.
2.Reset the air pressure on the tank to a range between 15 and 20 pounds per square inch (psi). The exact operating pressure for airbrush painting will vary, depending on the application and the type of paint used.
3.Reconnect an air-supply hose and a siphon style airbrush to the compressor.
4.Fill the airbrush's paint vile with lacquer-based paints. Test the air brush and paint performance on a piece of cardboard, or scrap piece of cloth
material before beginning the painting project. Every time the air compressor is connected to airbrush, or a new paint color is loaded into the brush, a short test spray should be performed. After each test adjust the air volume, and the paint flow in the gun to achieve the desired results8_16_2012_1_32_17_am.jpg
Aug 04, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
112 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
