Question about Stihl Garden
Stihl ms 350 doesn't start after running
Runs for a while. Shut it off and it won't start again.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
May have a weak Magneto, in that case. Or you have an air leak thru your oil seals on crankcase.
Posted on Jul 03, 2016
5 Suggested Answers
SOURCE: removing handlebar on stihl ms 270 chainsaw
you have to take the top cover off of the engine and then remove the tab that holds the bushing in place alongside the engine. if you just start prying on the plastic plug from the outside of the handle you will damage the retainer. that holds it in place. If you have already done this, there is a solution.
Posted on Apr 20, 2009
dontbother10
  • 2220 Answers
SOURCE: Kill switch not working
Brand new should be warranted; take it back to your dealer. Attempting to repair it yourself may void your warranty. Lou
Posted on Sep 02, 2009
fixya167
  • 119 Answers
SOURCE: stihl 025 doesn't have full stroke on pulling the the sarter cord, pulls about a foot then stop after many tries can get the full stroke, runs fine once started
has a knot got in? has it been out more in the past as someone mite of re tried it as for damage just to get going, three turx screws will let you in and have look it is easy, good look
Posted on Apr 11, 2012
  • 6468 Answers
SOURCE: My Stihl MS 290 won't run below half of a tank of fuel....runs great on full tank and just developed this problem
sounds like a split in the fuel line to the fuel filter
Posted on Oct 11, 2012
I have a Stihl MS 181C. It starts, no problem, but the chain runs on tickover and when I squeeze the throttle it cuts out. Can you please advise.
fuel filter --air filter --bad fuel--carb /cleaning /rebuild /replace-fuel line - binding clutch--tension to tight on chain
Aug 14, 2017 | Stihl Garden
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Stihl 180c runs wide open all the time.it has a new carb on it, linkage is fine
Stihl MS 180C Wont Run ' Arboristsite.com
www.arboristsite.com > Forums > Equipment Forums > Chainsaw
Aug 14, 2011 - 10 posts - ‎7 authors
I have a Stihl MS 180C that i cannot get to run. I used it all last year and went to use it a few months ago and it didnt seem ... it is not under warranty and i have pulled and pulled with choke on and throttle wide open and still wont start. ... Depending on the carb, some times you can just go for broke and get a ... Stihl ms 180 running rich
Jun 5, 2015
Echo cs-370, they actually work
Oct 12, 2010
More results from www.arboristsite.com
Stihl Chainsaw Troubleshooting Guide · TEK Indoor · Disqus
https://disqus.com/home/discussion/tekindoor/stihl_chainsaw.../newest/
Stihl
Dec 15, 2015 | Stihl Garden
Stihl ms 210. Starts ok revs fast then cuts out. Have to re start on full choke then run fast again on 1/2 choke and again stops after 2-3 seconds.
you have an air leak causing the unit to run to fast. The air leak is also over powering the flow of fuel causing it to die. Hopefully you have not tried running it repeatedly like this or you may have done severe internal damage due to running it to lean
Nov 19, 2014 | Stihl Genuine Ms 210, 230, & 250 Chainsaw...
Saw runs good but when shut off it wont start again for sometime
Check your fuel filter in case it is clogged. When starting pull cord on full choke 5 times quickly. Wait 2 or 3 seconds...try again if it asks like it wants to start..then put on 1/2 choke...goes thru same process. Check spark plug.
Sep 28, 2013 | Stihl 25" Chainsaw Saw Bar 30030008830 Ms...
Chain stops under load ms 660 stihl
your centrifical clutch need to be replaced there is no adjustment,I hope this helps you?
Oct 01, 2009 | Garden
Sep 02, 2009 | Garden
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
67 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
