Question about Denon AVR-1601 Receiver
Pre out for Sub woofer on AVR 1601 not working
    Sergeant:
    Champion:
  • 258 Answers
Is this a new problem, as in it worked before? If it's a new hookup, it's possible the sub you have isn't powered. In which case, it won't work. PRE out is 'preamp' for powered subs.
Posted on Jan 03, 2015
bluenadas
  • 203 Answers
SOURCE: The AVR-3300 power-off to stand-by mode
You have a blown amp or a leaky cap and the unit is going in to save mode to avoid destrying the unit.
Take it in for a repair. I don't think it should run more than $50-$75 for a fix depending on what component is bad.
Posted on Nov 19, 2007
SOURCE: AVR 810 Denon Receiver Sub Woofer Hookup?
Denon AVR-810 was a quite out-dated model. I had owned since 1992. It shown 'Protection' on the screen for 2 months ago and not yet been fixed. Better to replace a modern one or repair it at a reasonable costs.
Posted on Jan 04, 2008
  • 1694 Answers
SOURCE: Denon AVR-1601 Receiver
Check capacitors in power supply......also check for over-heated
resistors..all 1 ohm.....replace if cooked...................T.
Posted on Jan 05, 2008
petraman7
  • 1175 Answers
SOURCE: Manul denon avr-1601 en castellano
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Espagnol as well ...I think
Posted on Feb 16, 2009
  • 50 Answers
SOURCE: Programming a Denon AVR-1907 to activate the sub-woofer
In the setup menu on your denon receiver make sure the subwoofer setting is set to ON or YES.
Posted on Mar 07, 2010
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
I recently purchased a new Denon AVR-391 receiver and am having a problem hooking up my subwoofer. It seems that the Denon has a pre-out RCA looking output and my subwoofer uses conventional speaker wire. ...
Your sub-woofer apparently does not have an amplifier built into it. This type requires you to use your front left and front right speaker output to got through it to your regular speakers. It is called a passive sub-woofer for that reason.
To set it up, Connect your front speakers to the "output" of the sub. It should say "to speakers" on it.
Then connect the Speaker Outputs for the left front and right front on your Denon AVR-391 directly to the Sub. It should say on the back of the Sub "to amplifier".
Here is some theory you should know, if you don't already know it, that will help you get a satisfactory result in setting up this system.
There is a condition on setting up all speakers and subs that not everyone know. It's call "phase alignment". Phase alignment (A Good Thing) refers to all of the speakers in a system moving in the same direction (in and out) at the same instant in time. This gives you much clearer sound and better response from your sub-woofer.
Phase Cancellation (a bad thing) is when some of the speakers are moving out and other moving in during the very same instant in time. It causes problems in sound.
IN A SUB-WOOFER, IT CAN CANCEL OUT THE LOW NOTES.
Here is how to handle it:
On the back of the receiver the speaker terminal outputs are colored Red and Black. Black is considered negative and Red is considered positive. On the back of the Sub woofer and on the speakers the same colors apply. MAKE SURE THAT ALL OF THE CONNECTIONS GO BLACK TO BLACK AND RED TO RED WHEN CONNECTING UP THE SPEAKER WIRES.
The system will work either way. But you will have severe bass loss if the woofer wiring is out of phase because of phase cancellation.
Hope this helps,
Best Regards,
Mark
"Phase Cancellation"
Jan 05, 2011 | Audio Players & Recorders
Cant get klipsch sub woofer to work. do is there a menu setting through receiver to do this?
What model is the sub? Is your Klipsch sub powered? If it's already plugged in and powered on make sure you have the RCA cable going to the correct LFE output on the Denon and have it set to 5.1.
Jan 03, 2011 | Denon AVR-1601 Receiver
Sound from reciever
LFE (ONE CABLE ON THE SUB TO SUB OUT ON AVR) OR stereo L/R analog cable from sub to tape in/or out on avr (depends on AVR) LFE connection the sub turns up with the AVR - the stereo cable threw tape in/out on AVR only turns up via its own onboard amp volume from AVR has no affect.
Aug 21, 2009 | Sony STR-DH700 A/V Receiver
Danon avr 3200 subwoofer
LOOK ROUND THE BACK OF YOUR AMP AND YOU WILL SEE A SOCKET MARKED SUB PRE OUT.PLUG YOUR SUB CABLE INTO THIS AND THEN TO YOUR SUB.MAKE SURE YOU DO NOT PLUG INTO THE 6 CHANNEL IN AS YOU WILL GET NO SOUND.
HOPE THIS HELPS.
May 31, 2008 | Denon AVR-3200 Receiver
Nov 21, 2007 | Denon AVR-1601 Receiver
Denon AVR-1601 Receiver Logo
121 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
