Question about Singer 2662
Bobbin winding shaft will not turn
Followed manual instructions but I ca nhere motor running ut shaft will not turn. The bobbin is clicked into the proper position.
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 69 Answers
SOURCE: Singer 7444 trouble winding bobbin
It sounds like you don't have any tension on the thread when winding the bobbin. Make sure that you are running the thread through the tension disc on the top of the machine before going to the bobbin winder.
Posted on Mar 01, 2009
  • 1116 Answers
SOURCE: We have 2 singer 7442 machines and they will no
If you have followed the instructions and the winders do not work, the machines will need to be repaired, or you could purchase a Sidewinder Bobbin Winder and forgo the expense of having the machines repaired.
Posted on Mar 09, 2010
  • 4 Answers
SOURCE: Tiny Tailor bobbin won't wind
I don't know the solution but you can find the manual here:
http://www.singerco.com/accessories/manuals.html
Do search for TT600 when given the model number (do NOT use TT600X since it wll say not found). It's a very nice manual that is in PDF format.
Posted on May 31, 2010
I HAVE A KENMORE SEWING MACHINE 1641. I can't get the bobbin to wind. I have the manual and have followed all the instructions. Any suggestions?
When you push the empty bobbin over to engage the winding mechanism, do you hear it click into place, or maybe feel it click into place ? I am wondering if perhaps it's not quite engaged and that's why it won't wind. How old is the machine ?
Oct 02, 2014 | Kenmore Sewing Machines
Bobbin problems winding
Does the bobbin winder have a rubber o ring on it so that when the winder is in the winder position are the two making contact to wind
Mar 14, 2014 | Sewing Machines
Motor is running but not sewing, not pulling the fabric through
either your clutch is disengaged for bobbin winding mode or its got a drive issue internally.
Check that the clutch has been reenaged after winding a bobbin; somtimes this is a button inside the flywheel, a knob inside the flywheel you loosen (towards you) and tighten (away from you) to operate.
Or it may be just flicking the bobbin winding spindle which deactivates the main needle and feed dog drive.
If you don't have a manual to check the clutch instructions for your machine then visit the Singer website as most manuals are there free to download. http://www.singerco.com/accessories/instruction-manuals, type in your 4 digit model number and click "search" then wait for the page, when you see a red and white box "free download" click on that to open the pdf file.
If you are sure the clutch is reengaged, and there is still no movement, then you may need to take it for repair.
Nov 20, 2011 | Singer 3116 Simple
We have 2 singer 7442 machines and they will no longer wind the bobbin. Up to this point we followed the instructions the manual gave on how to thread and wind the bobbin. How do we fix?
Mar 08, 2010 | Singer 7442 Mechanical Sewing Machine
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Bobbin Winding message appears when machine is turned on
Is the bobbin winder holder clicked over to the right like you are trying to wind a bobbin? If so, and you are not trying to wind a new bobbin, click it over to the left.
Mar 09, 2009 | Kenmore 19233 Computerized Sewing Machine
Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
Bobbin winding not working on Kenmore 385.15243/15343
Have you tried tightening the bobbin screw?
Sep 04, 2008 | Kenmore Sewing Machines
Bobbin won't wind
I have checked the gears underneath and see no missing teeth for the bobbin part. The bobbin "seat" does raise, but does not engage. Thanks
Dec 23, 2007 | Sewing Machines
Singer 2662 Logo
23 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
