Question about Minn Kota Vantage 80 - 1352625
74lb. minn kota vantage, head wont go down, light comes on and i hear a click, worked fin last time out
Model # mkad26844738, head unit wont go down, I hear a click and the light comes on but wont move. worked fin last time out
SOURCE: The Minn Kota trolling motor
Mine did the same thing and i think that it could be the relay under the switch cause i had power when i directly touched both neg. and pos. so i would diffently take a look at that.
Posted on Oct 02, 2008
  • 8 Answers
SOURCE: Minn Kota lower unit leaking.
Man, you have a job ahead of you. First, if the unbreakable shaft is cracked or broken, you will have to replace it, for it will leak into the motor too. If your unit has the sonar sensor in the front and it has had water in it, the unit can corrode severely and need a lot of parts besides seals. The wiring to the sonar runs in a protective shield bonded to the magnet housing and one of the long screws holds it in there. Remember to take the wiring to the sonar out AFTER you remove the big motor feed wires, and replace it BEFORE you reinstall the red and black cables. Some grease seems to ensure the o'rings slide on metal parts during reassembly rather than tear. It's quite a job.
Posted on Nov 28, 2008
  • 10 Answers
SOURCE: Minn Kota electric motor MKJI1033962
Best to call Minn Kota direct for the manual Youll need your serial number thrust of motor and shaft length..
800-227-6433 they will help you with any technical questions.
Parts can be purchased from this dealer...There are schematics on the site for review....
http://www.northlandmarine.com/MinnKotaQuickRef.htm
=100){IAjax.Pop('/WorkArea/showcontent.aspx?id='+id);}else{__LoadTaxonomy(IAjax.getArguements(),'pagerequest=showcontent&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__ecmdiv='+tag);}}function OnDirectoryItemBubble(id,width,event){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=bubble&__ecmid='+id+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&bubblewidth='+width+'&X='+EBubble.EventX(event)+'&Y='+EBubble.EventY(event));} function DmsMenuInit(){ dmsDynamicContentBox = false; dmsCommunityDocuments = false; }function OnAddCategory(name, selectedTreeId, parentId, action, id, type, share){__LoadTaxonomy(IAjax.getArguements(),'pagerequest=addworkspacecategory&__categoryname='+name+'&control=ctl00_ctl00_ctl00_skin_body_variant_body_nav_body_Directory1&__selectedTreeId='+selectedTreeId+'&__folderId='+parentId+'&__action='+action+'&__taxonomyId='+id+'&type='+type+'&share='+share);}ektj$(document).ready(function(){DmsMenuInit();}); // --> .EkTB_overlayMacFFBGHack {background: url(/WorkArea/images/application/macFFBgHack.png) repeat;}
Posted on May 08, 2009
  • 10 Answers
SOURCE: proper batterie hook up on minn kota 70 thursh
Raventrans click this link to take you to a website which will you can click on schematics. I suggest adding a 50 amp fuse for your 70 lb thrust unit. scroll to the end of the schematic to find the battery hookup for a 24 volt hookup.
http://www.mikesreelrepair.com/./index.php
SOURCE: I need Minn Kota Power Drive operators Manual
I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
Posted on Jun 28, 2009
MINN KOTA MAXXUM FOOT CONTROL PROBLEMS
it has an electrical connection problem... check all the connections on the pedal control. your loosing connection making it die and when you kick it it connects again... look for a frayed wire. or a corroded connnection.
Sep 21, 2008 | Minn Kota Maxxum 80 Freshwater Bow Mount...
My minn kota 70lb thrust motor is 2 years old. Brand new batteries and it will turn left & right, but the prop will not work.????
Minn kota 74 lbs. prop runs when head turns when rotating motor from centre to right, but stops when you turn motor from centre to left. The light on top stays on.
Aug 30, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn-kota wiring battery charger 4 bank trolling motor e-drive
call the 800 number for minn kota on the head of your unit for questions or technical data. they will send you a copy of your manual also if you dont have it. i am not sure what your question is so ask them to save yourself time.
Jun 01, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Minn Kota power drive trolling motor will not steer to the right **** huard my minnkot will only steer left. I do not have a foot pedal, use the wrist remote control. even goes left when pressing down...
There is a good chance that he control board is bad. This is a common problem with these units. I have replaced my control board twice.. When the control board goes out, the some function of the unit will not work correctly while other functions work fine. The first time mine went out, the prop motor would not work. The last time the board went out, the unit would only steer right.
May 29, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
What size batteries needed for minn kota 24 volt 74lb thrust
I use Red Hot Mama batteries. These have held up for longer than any other brands that I have used. These are deep cycle marine wet ones.
Nov 12, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn kota 65
open up the prop area and look for / remove corrosion
Apr 06, 2008 | Minn Kota 55 PowerDrive Motor/Sonar Combo...
Minn Kota Vantage 80 - 1352625 Logo
877 people viewed this question
Top Minn Kota Water Sport Experts
Tom Chichester
Bill Boyd
Are you a Minn Kota Water Sport Expert? Answer questions, earn points and help others
