Question about Asko 24 in. D3530FI Built-in Dishwasher
Asko D5233 inlet valve clogged
I'm told that the inlet valve may be clogged, how do I check that myself before calling a repair person?
SOURCE: Asko Superior 1473-262 Dishwasher
the brown wire mounts toward the front of the dishwasher, and the green wire to the back spade
Posted on Jul 24, 2008
  • 14 Answers
SOURCE: ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Posted on Jul 08, 2009
  • 159 Answers
SOURCE: Asko D3530 water inlet fault code, water valve is
All im going to say is i think you have a faulty inlet valve.the water is probably only trickling into the machine & taking forever to fill,the computer board has probably picked up that the washer is taking to long to fill & has thrown up a fault code relating to the fill or inlet valve.Also sometimes if the filters in the bottom are clogged the water cant get to the wash motor & the motor cant load up with water.The motor runs without load on it & the computer board interprets this as slow fill or inlet valve problem.
Posted on May 28, 2010
geterrollin
  • 277 Answers
SOURCE: I have an asko D3530
Where you connect the water line from your house to the dishwasher you will find the waterline goes into a plastic body with an electrical wiring harness connected to it. You will have to take the panel off the back of the dishwasher at the water in line to see it. It is just an open/close electrical valve to control water flow
Posted on Jan 19, 2011
mc1bean
  • 3053 Answers
SOURCE: I have a Asko 3530
Hello, jorgen
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Asko dishwasher D5233 -- food particles left on glasses after wash
Your best bet is to clean the wash arms and drain filters at the base of the dishwasher. If this makes no difference then it is likely the diverter valve is not functioning and causes the drain water to mix with wash/ rinse water.
http://www.repairclinic.com/PartDetail/Diverter-valve/8801389/1489040
See manual
http://www.ajmadison.com/ajmadison/itemdocs/Asko_5233_ADA.pdf
Apr 20, 2014 | Asko Dishwashers
Asko 1375 will not fill completely
It needs to have the correct fittings you can call around and see if you can get a generic one that had the same threading for your reducer however it doesn't sound like a bad valve I think its the float switch that is bad
Jul 25, 2012 | Asko 1375 Dishwasher
Problem with ASKO 1385 dishwasher. Unit has manual cycle knob, not electronic. Clock/timer seems to work normally but no water is pumped in and a motor runs continually throughout cycle, even during...
CHECK THAT THE WATER IS ON TO THE UNIT, AND IF VOLTAGE IS AT WATER INLET VALVE. IF VOLTAGE THEN WATER SHOULD BE COMING IN EITHER BAD INLET VALVE OF CLOGGED SCREEN IF THERE IS VOLTAGE TO VALVE. NO VOLTAGE THEN CONNECTIONS OR TIMER WOULD BE NEXT.
Mar 09, 2010 | Asko 1385 Dishwasher
Asko D3530 water inlet fault code, water valve is on, water comes in but after water comes in for a couple of minutes we get a (inlet water fault code) check power at circulating pump no 120v unit will not...
It is common for these valves to "appear" to be ok, meaning they begin to allow water into the unit, but then one of the two coils or plungers inside fail, or are clogged with mineral deposit from the water or other debris.
Change the valve and you should be fine. part #1164471, you can find it at select parts depots or on-line retailers like repairclinic.com etc.
** Hire a pro or make sure to use a good replacement clamp on the fill line to the tub when you replace the valve, as well as some plumbers puddy/tape on the inlet fitting. Those little buggers have alot of water pressure going thru them when they open and I've seen them come off or leak due to insufficient fastening/loose clamps, then your machine goes into "flood mode".**
Asko seems to be repeating their past. On the earlier DW95 series (mid 90's to around 2000ish) they had a dual valve inlet which had a single valve rework issued to repair the faulty dual valves, now it looks like they're doing it again. Go figure.
Hope that helps, let me know.
Good Luck :)
Oct 28, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Jun 27, 2009 | Asko 1385 Dishwasher
Water inlet valve problems
repairclinic.com has parts available.
Jul 31, 2008 | Asko W620
Asko D1716 dishwasher problem
I also have an Asko D1716 dishwasher. The water stopped flowing. I replaced the water inlet valve and I have another problem, but the replacement of the fill valve is now letting in water. You can call Asko at 1-800-898-1879 to order the parts. If you order from Asko, I'm told you have some warranty on the parts. Anyway, the screws take a star drive and there is a front plate and back plate you will need to remove. There are approx. 4 screws on the front and 4 screws on the back. Just remember to unplug it before starting any work. The fill valve is in front of the machine. There are 2 screws holding it in place from the front. You will need to remove it out the back though to replace it since the fill tube to the tub is short and it wont allow you to pull it out the front. The repair is really easy once you get started.
Hope this helps,
Sargeantfod
Jun 11, 2008 | Asko D1716 Built-in Dishwasher
Asko Frontload wont stop running water
you need a new inlet valve take off the top panel then you see the inlet valve follow the inlet hose
Mar 17, 2008 | Asko W6441 Front Load Washer
Asko 24 in. D3530FI Built-in Dishwasher Logo
98 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
