Question about Honeywell Focus 6300B 5-2 Days Programmable Thermostat Heater
Honeywell CMS921B wireless t/stat, batteries went flat & heating wouldn't start, new batteries fitted heating works but display unreadable, only parts of numbers showing can it be reset.
Batteries removed left for 10 mins & replaced with no change.
SOURCE: Battery Issue
This worked! Thank you! It was 49 degrees in the house, and now the heater is working again.
Thank you and warm wished for the new year!
Mary
Posted on Dec 30, 2008
SOURCE: flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Posted on Feb 18, 2009
  • 116 Answers
SOURCE: how to remove thermostat cover to replace
the cover pulls off if it has a green screen then most likely takes batteries if does not light up then no batteries with a small piece of insulated wire jump from green to red if indoor fan does not come on then transformer bad
Posted on May 15, 2009
  • 587 Answers
SOURCE: The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
Posted on May 10, 2010
heatman101
  • 43501 Answers
SOURCE: A/C won't kick on w/
Okay it seems that for some reason the battery change scrambled the brain of the t-stat... that happens...
To fix it you will now have to go into the "Installer Menu" and reset the paramenters of the t-stat.
If you have the Installe brochure then you can look in there and then set the tistat for "heat/cool" and also to "auto fan" and then to "auto changeover" These should get you back to cooling again...
No big problem, just a small programming issue...be patient and if you do not have you book don't worry... you can look it up here...this tip tells you where and how to find any of the Honeywell t-stat manuals.
Manual Honeywell How to Find Honeywell Manuals
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
heatman101
Posted on Aug 21, 2010
Wiring with only 2 wires; which terminals to connect?
See RC and RH, RC is for cool, RH is for heat, you wire the red wire to the RH or red terminal ,either one will work actually but we generally switch the hot leg of power, W is the heat circuit
Dec 12, 2013 | Honeywell Electronic Programmable...
I replaced an old mercury T-stat (York with model number 2TH11704024) installed a new T-stat (RTH6350). The wires that I I have are O (orange), G (green), Y (yellow), T (gray but not used in new T-stat),...
Did you shut the power off to the air handler/furnace...... before you installed the new thermostat??? You may have shorted out the transformer or blown the transformer fuse...... If you try to put the Fan switch on the stat to Fan ON does the fan come on ..... if it does the transformer is OK.. On the new thermostat did you program it to tell it that you had a heat pump system ???? Looks like you had it wired right. Here is a pdf manual for a RTH6350 http://customer.honeywell.com/techlit/pdf/PackedLit/69-2416ES.pdf
Its on page 13 Advance setup for tell the new stat that you have a heat pump....There is also a Honey well Hot line on page 2 Hope this helps.
May 01, 2011 | Heating & Cooling
RC1 - New batteries fitted but display still blank.
Hi,Not nessarly shot.The stat uses low voltage from the equpitmemt also.You neea a volt meter to check.Remove stat from mounting plate.Check power at terminals RH&W or at RC&G they should read 24volt.If not check emergency switch off or fuse/breaker.
Apr 15, 2010 | Heating & Cooling
CT3600 display went out. Replaced all 3
My honeywell CT3600 thermostat went blank.
Replaced batteries - no change ?
Dec 25, 2009 | Honeywell CT3600 7 Day Electronic...
I have a honeywell t stat th6000 for htg only having problem get my gas valve to go onfurnace is working but no heat
As long as this is a 24 volt thermostat, remove the thermostat from the sub base and connect the wires that are connected to terminals R & W. If the furnace works the problem is in the thermostat. Have you tried new batteries
Oct 29, 2009 | Honeywell Electronic Programmable...
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Jun 13, 2009 | Honeywell Electronic Programmable...
No heat new thermostat
you have a short in the wireing.disconnect at air handler and hook-up short t-stat wire to t-stat,ifok chk wire to condenser
Jan 10, 2009 | Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
