Question about Maytag Dryers
How to replace a terminal block my Maytag Dryer
The terminal block is broken on my Maytag Electric Dryer MDE9606ayw. I need to know if it's a simple as it looks to replace it and if anything else could blown out when it broke.
  • 460 Answers
It is very semple just follow this diagram and will be simple.
http://www.partselect.com/ModelFrames.aspx?ModelID=149928&ModelNum=MDE9606AYW&ManufactureID=1&Selected=51473&Position=0&mfg=Maytag&Type=Appliance&Mark=0
Your Rating is very important for me
"Was this helpful?"
Posted on May 18, 2009
I have a 20 year old electric dryer that normally works great. All at once the dryer stopped heating, but otherwise works normally. I took the dryer apart, checked continuity of the heat coil, hi limit...
The problem is the terminal block, Vibration with the cord not being fastened to the block tight enough caused overheating at the block and it failed. Replace it.
Jul 19, 2013 | Dryers
Need a to change power cord from a 3 prong to a 4 prong on a maytag neptune electric dryer an I need the color codes
RED & BLACK go to L1 & L2 POWER terminals on the dryer (polarity is NOT aw factor on these 2 wires) the WHITE wire goes on the N- NEUTRAL terminal usually the center terminal between the 2 POWER terminals on the 3 terminal power block on the dryer,then the GREEN wire is the safety ground and is connected on any METALLIC spot on the dryer case,usually theres a screw somewhere just off the 3 wire terminal block mentioned above
Mar 08, 2012 | Maytag Dryers
My maytag electric dryer #MDE9606AYW will not start, fuses and switches seam to be fine
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 26, 2011 | Maytag Dryers
My Maytag MDE9606AYW drum randomly decides to not start. I hit the push button and there is loud noise but the drum doesn't move. When it does start the loud noise happens but it is quickly replaced by...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
May 02, 2011 | Maytag MDE5806AY Electric Dryer
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
Electric dryer won't start
HI, check the following to address this issue you are experiencing.
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
Jun 02, 2009 | Maytag MDE2600 Electric Dryer
I have a Mytag Dryer MDE9606AYW The drum won't tumble
Unplug the dryer, open up the top panel. check if the belt is broken . replaced it.
Feb 24, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Dryer Squeaking noise when first turning it on
nedd to replace the rear tub rollers
Apr 21, 2008 | Dryers
Maytag electric dryer not heating
2. Heating element
3. Thermal fuse
Nov 01, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
183 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
