Question about Powerware Series 5 5119 UPS System
Powerware 5119 2000i - schematics?
After mistake switching extern voltage (230V) to the UPS-output while working on battery the middle power stage is blow up. After replacement of FET's the inverter is not working - only starts for 1sec.
has anybody a schematics from this UPS?
pravinbhavsa
  • 348 Answers
SOURCE: My UPS Powerware 9120 6kva. At inverter section.
no but I can tell you that for old ups mosfets are used and for new ups IGBT (insulated gate bipolar transistor )are used the IGBTs are not available on shops you have to take help of company
Posted on Mar 08, 2010
  • 195 Answers
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
  • 25 Answers
SOURCE: control board for powerware 9120 6kva ups
did you get what you needed?
Posted on Jul 11, 2009
  • 4 Answers
SOURCE: replacement fans for powerware 9120
9120 fans are rare and uncommon, for alternate solution just replaced the bearing of the fan.
Posted on May 27, 2010
  • 4 Answers
SOURCE: my ups has is faulty i need a circuit diagram to fix it
I had a DC bus fault error displayed.
So I unplugged battery, then turned on UPS. It said Batt disconnected of course.
So when I plugged in the batt while the UPS was on, and held the power button for a few sec, the UPS displayed Batt testing.
After a few moments it was back online and had no faults!
Worth a shot.
Posted on Dec 09, 2010
I have a "low A/C output" message. Is this related to a faulty DVR or another board?
From the user manual: http://lit.powerware.com/ll_download.asp?file=Eaton%20FERRUPS%20User%20Guide.pdf page 108.
The output voltage is below the alarm setting as determined by setup parameters 59 and 60.
Verify the output voltage using a voltage meter. If correct, verify setup parameters 59 and 60. If alarm condition continues, bypass the UPS and turn the UPS switch off. Call your service representative.
Mar 17, 2015 | Powerware FERRUPS FE4.3 - UPS - 4300 VA
How can output voltage be adjusted when on battery power?
1. check either it is overloaded or the batteries are weak . check battery voltage to
May 10, 2014 | APC 620VA/390W Input 230V/Output 230V...
Battery Packs for Powerware 9355 UPS
The Batts can be charged externally, then refitted, usually I extend the DC cables so I can work with the batt outside the unit. This is ONLY to be done if you understand the risk and what may happen if you get it wrong.
Batts are always live and can cause fire/explosion/severe burns if shorted!
IF YOU ARE NOT SURE THEN GET SOME EXPERIENCED HELP!
OK so the UPS will not normally recognise a very low batt pack, that is the reason you can not start the test, this test will back of the rectifier so the batt pack takes the load for a short period.
If the batt pack is out of range then this will make the load go off, so the UPS is designed not to allow the test,unless the batt is at the right level.
If you can get the batt pack up close to normal then the unit will recharge it to full.,Wait until it is fully charged before testing.
If this is sucessful the cyle the batt a few times allowing it to reach around low batt warning before recharging. This will assist the batt in recovery. During this process if possible monitor with a test intrument(fluke 123 or 43B will do) the batt pack discharge curve , once the batt pack has dropped to its charge level from float, it should be a smooth decay.
depending on the state of the batts you may be ok, if there are weak ones in the string then you may have to replace all of them depending on the age of the batt pack.
MAKE SURE YOU ARE VERY CAREFUL WITH BATTERIES, THEY ARE VERY DANGEROUS, AND ALWAYS LIVE!
Check you manual for safety procedures, BEFORE working on Batteries.
hope this helps
thanks for using Fixya
Feb 03, 2010 | Powerware 9355 UPS System
Powerware 9120 BUS Unbalanced error display
I've had this same issue what it boils down to is that the Power IN is not being distributed properly across the Power Outlets.
Step 1. unplug everything from the unit and power the ups down. If the alarm clears itself the UPS is mostly likely fine. if it doesn't not clear send it in for repair
Step 2. If step 1 cleared the alarm try distributing the decives across the outlets differently.
There are two inverters so two output if everything is plugged into one side (ie a power bar with 10 things plugged into it) and nothing on the other side this could cause the alarm.
hope this helps
Dec 11, 2009 | Computers & Internet
Hi i jus need box and speaker specs for the dual 2 ohm 10pw3
General Information Manufacturer: Eaton Corporation
Manufacturer Part Number: 103004248-5592
Manufacturer Website Address: www.eaton.com/EatonCom/Markets/NorthAmerica
Brand Name: Eaton
Product Series: PW3105
Product Model: PW3105 700
Product Name: Powerware PW3105 700VA Tower UPS
Product Type: Standby UPS
Technical Information Plug/Connector Type: NEMA 5-15P
Receptacles: 4 x NEMA 5-15R - Battery Backup System
Switching Time:
  • 6 ms
  • 6 ms
Dataline Protection: RJ-45 Internet
Power Description Load Capacity: 700VA/420W
Input Voltage: 110V AC
Input Voltage Range: 0V AC to 160V AC
Output Voltage: 115V AC
Frequency:
  • 50Hz
  • 60Hz
Management Overload Protection: Circuit Breaker
Interfaces/Ports Interfaces/Ports: 1 x USB
Battery Information Batteries: Maintenance Free Sealed Lead-acid
Backup/Run Time: 3 Minute 420W Full-load
Physical Characteristics Form Factor: Tower
Dimensions:
  • 4.4" Height x 11" Width x 7" Depth
Weight: 9.7 lb
Miscellaneous Certifications & Standards:
  • Safety: UL 1778 3rd Edtion/CSAC22.2 No107.3, Designed to meet UL497A
  • EMI: FCC Class B
  • Software Included: Powerware LanSafe Software
    Green Compliance: Yes
    Green Compliance Certificate/Authority: RoHS
    Jan 22, 2009 | Powerware PW3105 700 (103004248-5501)...
    Battery charging problem
    well, the charging voltage is the right one, you may have a problem with charger board, did you check that? tbe 2 big capacitators, maybe you will need to change them, there could be a couple of things, and to be honest i don´t have the circuits sheets, cause i stopped working with powerware.
    good luck.
    Jul 29, 2008 | Computers & Internet
    Changing input frequency of Powerware 9315-80 Model 65 UPS
    Unfortunately, it seems that you UPS is mostly designed for 60 Hz. However, there seems to be an exception for 380-415V input / 380-415V output where 50 Hz is supported.
    Of course, 380-415V is not usable for IT systems as is, you would then have to transform it back to 208V or whatever voltage your infrastructure is requirering.
    Check out the table at page 2 of this document:
    http://www.armspower.com/Products/Powerware/Powerware9315/Powerware®%209315-80%20UPS%20Data%20Sheet.pdf
    One thing that is not specified in this document is if the UPS can be easily switched from one input voltage to another or if you need to replace some parts.
    Hope this helps.
    Jan 19, 2008 | Computers & Internet
    Powerware Series 5 5119 UPS System Logo
    260 people viewed this question
    Top Powerware Computers & Internet Experts
    Vassilis Chamaidis
    Level 1 Expert
    Jax Planet
    Jax Planet
    Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
