Question about Logitech Harmony 1000 LCD Touchscreen Remote Control
MY REMOTE IS FROZEN. THE LIGHTS GO FOR A FEW SECONDS THEN OFF. PROBLEM I CAN'T TURN ON, CHANGE CH. NOTHING. ONE TIME I GOT HELP THRU CUSTOMER SERVICE THEY HAD ME RUN SOME APPL. BUT I DON' T RECALL WHAT IT WAS. CAN YOU HELP. MY REMOTE MODEL IS THE HARMONY 550. THANKYOU
  • 6 Answers
SOURCE: remote appears frozen
I got the same issue with mine, and hooking to the computer and upgrading the firmware worked for me. I first had to take the bateries out and let it sit for 24 hours so it would loose the codes inside. No problems after that.
Posted on Jan 31, 2008
SOURCE: blank screen on the Harmony 550
I had the same problem - my kid stuck it in her mouth and then the screen stopped working. I was finally able to fix it by doing the following:
1. I took the remote apart by
a. taking out the four screws under the battery cover.
b. then, I used a small slot screwdriver as a wedge and ran it up the length of the edge of the remote while prying the top and bottom apart.
2. Once i had it apart, I took a blow dryer to it to blow out any dust and get rid of any moisture
3. I put it back together and it was in Safe mode
4. I took out a battery, held down the #2 button, and put a battery back in and got the "Update Successful" message
5. To my surprise, the remote was fixed.
Posted on Mar 01, 2009
  • 86 Answers
SOURCE: harmony 550 in safe mode
Hi There,
To get out of safe mode, do a firmware update from your PC. This will install the latest firmware and your configuration. Safe mode is a bootstrap designed to recover from firmware corruption issues so about the only thing it knows how to do is reload firmware.
However, if the remote fails to communicate with the PC when it is stuck in Safe Mode, please try the following.
1. Remove the batteries from the remote & check for any stuck buttons especially the Power button that may be causing the remote to stay in this state.
2. If it still will not apply firmware to get out of safe mode, then still without batteries hold down the #2 button while plugging into USB, and it should exit Safe Mode, and say something similar to 'Firmware Upgrade Success'. Even though it says this, still perform the Firmware upgrade since it was stuck in Safe Mode to begin with.
Posted on Aug 29, 2009
SOURCE: Harmony one is frozen
Let me see if I understand how this works. If I have a problem that I can't fix you charge me $12.99 to $19.99 and then you will try to fix solve my problem -- if you can't there is no charge other than my waste of time dealing with you.. However if I already solved the problem then you want me to tell you for FREE how I solved the problem!
Tell you what I will do -- you send me a check for $12.99 and I will tell you how I solved fixed my Harmony One.
I am betting that I won't hear from you again. How do you sleep at night.
Posted on Oct 10, 2009
Testimonial: "??????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????"
SOURCE: 'Welcome to your remote'
Same here, button stuck. Many thanks to all
Posted on Feb 06, 2010
Sanyo p42840-06 channel menu comes on then goes off led power stays on.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Dec 07, 2016 | Sanyo Televison & Video
Tip
Television factory resets
Factory Resets / modes
For all listed procedures, start with TV on, in TV mode, unless otherwise instructed. After procedure is complete, unplug set and re-plug in to finish reset.
If more than one procedure is listed for a given manufacturer, try the different ones until you see which one works for your set.
Coby:****************************************-
Enter menu, hi-lite "audio" then enter 8893
mode/source 2580 select "other setting",select "shipment" then yes, after it exits service menu you need to power set off.
Dynex ****************************************-
source/input 2580
hold vol down on tv and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
source/input 2580
menu 1999 (tv is on)
Element ****************************************
menu 0000
menu 1147
Haier ******************************************
pull up menu, hi-lite "audio" then enter 8893
Hisense *****************************************
In customer menu go to"Parental" enter 0000 then select"Clean All" then power the set off and back on and first time setup menu will be there.
For some models, same as above model except in menu it is labeled "Lock"
Insignia *****************************************-
input 2580 (tv is on)
Mitsubishi ****************************************
Menu 123 or menu 2470 (tv is on)
Panasonic
Hold vol- on TV, press and hold menu button on remote
Philips ******************************************
Push menu, select"Features"then select"current software info" push 062596-info on remote then push info again then red"initialize appears and changes color then complete. Push power button to exit
TV is on,push 062596-info on remote,then push info again, red"initialized"appears it turns green when completed, then push power button to exit
Polariod *****************************************-
Hold vol- and chan- or hold vol+ and chan+ (tv is on)
Proscan ******************************************
In customer menu go to setup,select parental control menu, enter 0000 then select "clear channel list".
RCA *******************************************-
Menu 1147
Sanyo *******************************************
hold vol down on TV, press and hold #1 button on remote, vol will jump to halfway and set shuts off. Turn back on have 1st time setup screen.
Samsung *****************************************-
Mute 182 power (tv is off)
(On some models, Factory Reset is on this menu, on some, you must go into the "Options" submenu
Seiki ********************************************-
Menu 0000
Sharp ********************************************
(Note - On Sharp models, you will need to look through the menus to find the reset option)
menu 1999
menu, 3481
menu 1147
while holding vol- & input buttons on tv plug in set when "k" appears push vol- & chan-
Sony *********************************************
Hold "arrow up" on remote and push power button on tv (tv is on)
Symphony *****************************************-
Source/input 2580
Toshiba ******************************************-
on Menu, select "Installation", then "System Information" press the right arrow button, ("System Information" will change to "Factory Reset" or something similar) follow on-screen instructions
Vision Quest ***************************************-
Source/input 2580
Vizio ********************************************
In customer menu under "Help" tab is Factory Default enter 0000
Vestel (most):
Menu 4725 then select "RESET"
Samsung (European):
Power off, Info - Menu - Mute - Power, then find factory reset and execute option.
LG/Zenith:
Hold MENU on TV and MENU on remote for 5~10 seconds, then select reset option.
NEC:
While powering on hold "MENU" or "INPUT" on TV, depending on model. (Only disables error lock out/buffer and puts TV in temporary service mode.)
To reset to factory, on remote, Off Timer - Menu - Exit - Off Timer, then select reset option.
Vizio Service Menu Method 1
1.Turn The TV off.
2.Press and hold the {CH +} & {CH -} buttons on the TV.
3.Then press and release the {POWER} button on the TV.
4.Release the {CH +} & {CH -} buttons.
5.Now press the {MENU} button on the remote.
6.You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This is for factory).
7.Press and hold the {MENU} button for few seconds.
8.The Service Menu will be displayed.
Vizio Service Menu Method 2
1.Turn The TV off.
3.Then press and hold the {POWER} button on the TV.
4.Keep all three buttons pressed for few seconds.
Vizio Service Menu Method 3
1.Press and hold the {EXIT} button on the remote for 3 seconds then release it.
2.Then press the {1} {2} {3} buttons on the remote.
3.To exit, press the {EXIT} button.
GV42L FHDTV10A / JV50 / SV42 / SV320XVT / SV370XVT / SV420M / SV470M / SV420XVT1A / SV470XVT1A /
VECO320L1A / VO22L / VO32 / VO37 / VO47L / VOJ320 / VOJ370 / VP322 / VP42 HDTV20A / VP422 / VS420LF1A /
VU42 / VW32 / VW37 / VW42 / VX20 / VX32 / VX37 HDTV10A /VX42
Push "Menu" on remote and then push "Vol-" and "Input" on keypad
GV46 / P50HDM / P50HDTV10A
Press "Ch-" and "Ch+" buttons together once on keypad
GV42 / L42 / VP42HDTV10A / VP50 / VX37
Press and release "Menu" on keypad. Hold "Ch-" and "Ch+" buttons on keypad, then hold "Menu" on remote.
P42
Hold "Ch+" and "Ch-" along with "Power" on keypad. OSD will show "F" on right bottom portion of OSD.
VM60P
Press "Info" on remote, then press "Right Arrow," "Down Arrow," "Left Arrow," "Up Arrow," "Right Arrow."
The TV will show "Enter Factory Mode." Press "Menu" after message disappears and go do to "Setup."
GV47
Press "Menu" then press the following combination: "Info," "8," "2," "0," "6."
SV420M / SV470M / VF550M / VF550XVT1A / VF551XVT / VL260M / VL320M / VL420M / VL470M / VO320E /
VO320EP8 / VO370M / VO420E / VP504 / VP505
Press "Menu," and then press "2," "4," "8," "9."
VA19 / VA22LF / VA220E / VA26
Press "Menu" and then press the following combination: "0," "6," "2," "5," "9," "6"
VA320E / VA320M / VA370M / VT420M / VT470M
Press "Menu" and then press the following combination: "1," "9," "9," "1"
VW22 / VS370E
Press "Mute" once OR "-" twice (the dash next to the "0") and then press the following combination: "9," "8," "7," "6"
Main Page
on Apr 23, 2015 | Televison & Video
Resetting without going to the menu for a vizio m220nv
Get into the Vizio TV service mode
There are to options to get into Service mode:
Option 1:
Turn the Vizio TV off.
Press and hold the CH + & CH - buttons on the TV.
Then press and release the POWER button on the TV Vizio.
Release the CH+ & CH- buttons.
Now press the MENU button on the remote.
You should get your regular menu up, but with a "F" in the bottom right corner of the menu (This if for factory reset).
Press and hold the MENU button for few seconds.
Option 2:
Turn off th Vizio TV.
Press and hold the CH+ & CH- buttons on the TV Vizio.
Then press and hold the POWER button on the TV.
Feb 18, 2013 | Vizio M220nv 22-inch Full Hd 1080p Led Lcd...
Codes to use dish network remote on cyberhome dvd player
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once a second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SATmode. Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Sep 01, 2010 | Cyberhome CH-DVD 300 DVD Player
Need code for my dvd so I can use dish network remote cyber home dvd
Step 1:
Press and hold the DVD mode button until all mode button back lights illuminate,then release.
Step 2:
Step 3:
Step 4:
Phillip Chang
Jul 15, 2010 | Cyberhome CH-DVD 300 DVD Player
How do i adjust centering the the picture? can it be done with the remote?there are no external adjustments.
with tv off press and hold both CH- and Vol- at same time untill tv comes on you should now be in service menu.
Feb 15, 2010 | RCA 20F511T TV
Ch 9 picture froizen.has sound.cannot change
U have cable,some kind of pay tv?Tries unplug the cable box,replug the box for reset or to update new solfware for the box.If u have free air tv,get better antena like out side door antena or a digital antena.Also should change the batteries in ur remote and clean the IR lights both remote and tv make sure no blocking path to signal.
Oct 31, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
Motorola dvr dct6412 locked channels
Check with your provider to ensure that you are in expanded services, or limited. Because being on limited services the box will lock you out of those channels. If you are in billing for those services and you checked the batteries on your remote and they are good and you get a solid red blink when you change channels not a double blink (indicating that your batteries are dying), Then try power cycling your DVR by, removing the power supply and waiting 3sec then plug it back in. Your box should shut off, turn itself back on, then go into the load screen, then, once the load screen display shows on your tv and on box display, wait for your box to completely load (don't touch nothing until the correct time shows up, meaning that it has completed the load process) Once the process is complete turn box back on and you should have you guide back up and (No Data) on your program schedule(Don't Worry!!) it will populate, with 15-20 mins.
Now try to ch. up and down and see if that fixed the problem. also make sure nothing is blocking the sensor. If all else fails and you changed the battery, called your cable provider and request a box swap, (be sure to watch all your recorded shows because they go bye, bye with the cable guy!)
Sep 22, 2009 | Arris DCT6200 DTV Receiver
Hitachi 51SWX20B projection TV has no picture or sound
first lets check the remote to see if its working , with a digital camera facing the front end of remote (where THE EYE is) look thru the camera screen while pressing any button from remote , you should be able to see FLASHING LIGHT coming from the remote. SECOND about your TV , better off to have unit check by an authorized tech . hope this helps
Apr 27, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Dvr 50
Hi I have jamo Dvr50 system and it has been frozen since yesterday. I have power down few times but nothing is happening. It comes on and panel lights up but that is all.
Nov 08, 2007 | Jamo DVR-50 System
Open Questions:
See all Logitech Harmony 1000 LCD Touchscreen Remote Questions
Logitech Harmony 1000 LCD Touchscreen Remote Control Logo
Top Logitech Televison & Video Experts
Greg Ulan
syspro
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
