Question about Blaupunkt GTA 260 2 Channel Amplifier 400 Watt Amp
Amplifier doesn't power-up
Amplifier Immediately goes into PROTECT mode with a Red LED shown. Can somebody please explain to me what might be causing this??
  • filthyscum66 May 19, 2009
    Thank you for your in-put and advice. I found out theat the Ground terminal was not connected to an appropriate part of the chassis and was therefore not completing the circuit. The PROTECT LED must have been powered by the stereo.
  • 15,935 Answers
3 possible reasons you amplifier is trying to protect itself.
* Ground sensed on Positive terminal - could be shorted wire, stray wire strands from terminals, blown voicecoil on speaker - speaker wire touching ground.
* Thermal/impedence shutdown - Amplifier load is below rated minimum, amplifier has been overworked and is too hot (mostly due to improper load or gain setting too high.
*Internal Problem - Output channel or IC blown... causing an internal fault.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 18, 2009
  • blueextc3221
    blueextc3221 May 19, 2009
    Please rate as fixya.
    Thank you
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
I wanna supplied my Amplifier Lanzar MNX 250 with an 12V - 30 Ohm battery, but the led of my amplifier is red and my speaker doesn't play music. How can I fix the "protect mode" in which the...
  1. The battery is 12 volts and Ohms has nothing to do with your amp installation.
  2. Was the amp running and got hot? Many times an amp will go into "thermal mode" when used for an extended amount of time and need to cool down but I assume if you are trying to hook it up you were not using it.
  3. You need to check the ground wire real well. A loose ground will cause protect mode.
  4. Recheck the speaker wires and their connections. If they cross this to can cause protection mode.
  5. This is a 4 Ohm amp, are your speakers 4 ohm or lower> If not then you may be running to low of a load to your amplifier.
  6. I always remove everything from the amp first and power it on and then add wires and see where which connection throws the amp into power mode.
  7. Check the fuse as well but if the LED is on chances are your fuse is good.
  8. If you check all of the items I listed and the amp still goes into protect mode then your amp is bad.
Regards, Tony
May 05, 2011 | Lanzar MNX250 2Channel Car Amp
My phoenix gold x200.4 amp turns on but the protect light keep on flashing
  • What does it mean when the LEDs flash on my amplifier?
    With most recently produced Phoenix Gold amplifiers, a flashing/blinking LED is an indication that the unit is in protect mode, usually due to an overcurrent condition caused by an internal short, external short (speakers), or low impedance. Overheating will also cause the amplifier to shut down temporarily.
    If amplifier remains in protect mode, power down the amplifier, disconnect the speakers, and power up again. If LEDs continue to flash, there is probably an internal problem with the amplifier that will require service attention to fix.
  • Sep 23, 2010 | Phoenix Gold ZX600ti Car Audio Amplifier
    Where can i get a free copy of schematic diagram for amplifier
    Generally a "protect" mode would be triggered by a shorted output (speaker). I would suggest disconnection all of the speakers to see if the red light goes off.
    Mar 16, 2009 | Car Audio & Video
    Protection mode
    It's normal for some amps to go into protect for a few seconds when initially powered up. If it remains in protect mode, it may have shorted output transistors. To eliminate other possible causes, read through the following troubleshooting page:
    Amp in Protect Mode - Troubleshooting
    Let me know if you have any other questions.
    Dec 11, 2008 | Phoenix Gold Titanium 800.1 Car Audio...
    The red light is on but there is power to the unit. no visible
    If the red light is the protect LED, the amp probably has shorted output transistors. To eliminate other possible causes, read through the following page:
    Nov 25, 2008 | Power Acoustik SL2-2000 Car Audio...
    Amp shut down no power
    If the red light is the protection LED, the amp probably has shorted output transistors. Read through the following page to eliminate other possible causes.
    Nov 13, 2008 | Pyle (DBPLA2480) Car Audio Amplifier
    Red status Light
    If the protection LED is lit, the amp is in protect mode and probably has shorted output transistors. To eliminate other possible causes, read through the following page:
    Amp in Protect Mode - Trubleshooting
    Nov 07, 2008 | Boss AUDIO RIP-596 2-Channel Ripper Series...
    Sounstream tra 560.2 always in 'protect'
    It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
    Amplifier in Protect Mode - Troubleshooting
    Nov 01, 2008 | Soundstream Tarantula Car Audio Amplifier
    How to change the Red Protect light to Green Power.
    If the amp goes into protect mode, it's likely due to shorted output transistors. To eliminate other possible problems, read through the following page:
    If the problems are not with the wiring, follow the link at the bottom of the page to the Amplifier Repair Primer page.
    Sep 21, 2008 | Audiofonics ADF-240 Car Audio Amplifier
    Blaupunkt GTA 260 2 Channel Amplifier 400 Watt Amp Logo
    337 people viewed this question
    Top Blaupunkt Car Audio & Video Experts
    xxxxxx xxx
    Colin Stickland
    Colin Stickland
    Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
