Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I have GE gl44 stove. Broiler works but oven does not work. Igniter will not glow
bigg t
  • 640 Answers
SOURCE: Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Posted on Aug 28, 2007
  • 3422 Answers
SOURCE: GE XL44 gas oven
Please CLICK HERE for the instructions.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 21, 2008
SOURCE: GE JGBP34 (XL44) oven won't light
Look at Lower Igniter
Check these two Sites here:
http://www.fixya.com/support/t141325-ge_xl44_range
and
http://www.fixya.com/support/t130970-ge_xl44_gas_oven
I just got this same problem today. Will do the same thing as these guys said in the morning. Good Luck.
Love these fix-it sites.
Posted on Jan 10, 2009
SOURCE: GE Gas oven not coming on (ignitor not glowing at
The ignitor just needs replaced . you can find the parts using your stove model # . its two screws and a wire to replace .
Posted on Feb 05, 2011
  • 288 Answers
SOURCE: I have an 8 year old GE profile slide in
Sounds like a problem with the gas going to the oven is not coming on. Because this could be a gas issue I would recommend getting professional help.
Posted on Sep 12, 2013
Oven not lighting
Replace the oven igniter. If it is a flat/rectangular shaped igniter use part# 5303935066:
Range Stove Oven Igniter 5303935066 .
If it is round, use part #:
Range Stove Oven Igniter 4342528
Jul 12, 2016 | Kitchen Ranges
I have an 8 year old GE profile slide in oven/stove, model JG968SEK. The range is working and the broiler is working. The oven is not working and the igniter wasn't "glowing" so I replaced the igniter. ...
Sep 12, 2013 | GE Kitchen Ranges
GE Gas oven not coming on (ignitor not glowing at all) ge jgsp28sek4ss Broiler works, stove top works, oven igniter not coming on Thanks Jim
Feb 05, 2011 | GE Kitchen Ranges
Broiler works oven doesn't heat
Based on your description, the igniter is dead.
The broiler and the oven heat each have their own igniter. Look for the characteristic glow when the oven is turned on. If it is not visible, then you will need to replace the "OVEN" igniter...
Google the stove model for repair parts and locate the igniter. Not too hard to replace... directions are packed with the new igniter...
Jan 08, 2010 | Maytag MGR5750 Gas Kitchen Range
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
XL44 oven will not work
The fact that the igniter on the broiler actually begins to glow rules out your Electronic Oven Control (EOC) board. Usually when both oven features fail to work the EOC, or wiring, is the culprit. But...in your situation, the broiler igniter glows, but the bake igniter doesn't. You don't see this happen very often, but I believe you may have two bad igniters. The following link explains how to replace an igniter and gives you some theory behind how they operate:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
Although an igniter glows, it still may be bad. This is usually dependent upon the age of the stove and the frequency of use. Usually, the bake igniter burns out first, because it is used more often. These igniters also grow weak with age. Which means, if they do not draw the required current necessary to open the gas safety valve, you will not have ignition. This is a designed safety feature that prevents free flowing gas from filling the oven box before ignition. I would recommend replacing both igniters to see if this corrects your problem. If you require additional assistance, or have questions, please let me know before you rate the solution. I hope this helps solve your problem.
Feb 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Hotpoint oven glowbar not working
My oven glowbar stopped working christmas morning. Yesterday we bought a whirlpool brand (igntr-oven #4342528) because it is twenty something dollars cheaper then GE. My husband installed it today. The only difference is you have to splice the wires (it comes with everthing you need) The first time he put it in it did not work because he had the wires backwards. He switched the wires and now its working fine.
My oven is two years old also.
Dec 27, 2008 | Ovens
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
