Question about Philips TP2784C TV
Philips Magnavox TP2784C TV always powers up to Channel 9
Even after "deleting" and "blocking" channel 9 with original remote and correct access codes, it powers up to Channel 9.
Now in the Digital Age all TV's must be tuned to Channel 3 in my area, and then switched via Digital Converter to desired channel.
I am pondering finding another TV! Help, and thank you in advance if you can help.
  • 15 more comments
  • Litza60 May 18, 2009
    I had it unplugged all night hoping it would lose its memory to no avail. I will try your particular suggestion in the next 15 minutes. Thanks for the prompt response Master Tom2-Tom2. BTW what is that creature in your avatar?
    Tom2Tom2.
    I
    Tom2Tom2.
    I tried your
    Tom2Tom2.
    I tried your suggestion, but the TV
    Tom2Tom2.
    I tried your suggestion, but the TV still powers up
    Tom2Tom2.
    I tried your suggestion, but the TV still powers up at CH
    Tom2Tom2.
    I tried your suggestion, but the TV still powers up at CH 9.
    Tom2Tom2.
    I tried your suggestion, but the TV still powers up at CH 9. Anybody
    Tom2Tom2.
    I tried your suggestion, but the TV still powers up at CH 9. Anybody else have a
    Tom2Tom2.
    I tried your suggestion, but the TV still powers up at CH 9. Do you
    Tom2Tom2.
    I tried your suggestion, but the TV still powers up at CH 9. Do you have
    Tom2Tom2.
    I tried your suggestion, but the TV still powers up at CH 9. Do you have any
    Tom2Tom2.
    I tried your suggestion, but the TV still powers up at CH 9. Do you have any other
    Any other suggestions oh FixYa people?
  • Anonymous May 19, 2009
    its possible that its the remote sending the channle nine signal or the IR sensor on the tv or the eeprom chip needs resettting or replaced or a component in the circuit
  • Litza60 May 19, 2009
    TV still misbehaving. Remote suggestion by Guest interesting, but removing batteries from it didn't stop the TV from powering up at CH 9.
    I would like to reset the eeprom chip memory, but can find no info as to actions required.
    Anybody else?
  • Litza60 May 21, 2009
    Thanks for that suggestion Tom2Tom2. Any idea if that chip is a plug in model, or is it soldered in? Not so sure I want to use my $5 soldering weapon to solder a TV that I hope still works afterwards!
  • 110 Answers
Unplug unit from AC outlet for 10 - mins then plug back in to AC. Turn unit on select channel 3 turn off and back on.
Posted on May 18, 2009
  • 1 more comment
  • TOM2-TOM2
    TOM2-TOM2 May 18, 2009
    I don't know but I like the thing!
  • TOM2-TOM2
    TOM2-TOM2 May 20, 2009
    Sorry that didn't work for you.
    You will have to replace the eeprom IC if that didn't work.
    IC 7088 Part# 9322 095 35682.
  • TOM2-TOM2
    TOM2-TOM2 May 21, 2009
    It' a solder onto the board should be 4 or 6 pins.
    Help me out and click on the hand it the info helped you thanks.
    Problem Solver:
  • 6 Answers
Your TV will reset to whatever channel you last had it on when you were using the basic- antenna or non-digital cable- line. Switch to that line, set the channel that you wish your television to open to, and it ought to open there each and every time.
If this does not work, occasionally, the set will reset to the station used in the auto segment of the time setting program. To see if it will reset, switch to the time setting program, choose the "auto" optoion, then, when it asks for the station where it can find current time, choose the channel you would like to set to open on each time. Let the time program run through its completion. Unless the station you choose just happens to be one that transmits the current time, allow the program to complete until it reaches it fail point. Go back to your usual viewing channel, turn the set off, then on, and see if it reset.
Posted on May 09, 2010
  • artfuldod993 May 10, 2010
    I did some further investigating and it is possible that the station preset for your timer function could also be causing your problem with the TV always opening to channel 9. Try going into the Timer Activating function in the FEATURES section. Display the TIMER controls, cursor right and down to highlight the CHANNEL control. Cursor right again to highlight the channel indicator area. Press the NUMBER buttons to enter the station that you would like your TV to open to each time, then press the STATUS/EXIT button to close the menu. Hopefully, if none of the previous attempts worked, this will resolve your problem.
How to reset access code on magnavox 20ms233s
Hi. It's really necessary to have the original remote. All so called replacment do not have the "menu" button. In Philips TV's access code is not rquired. In your case, some channels are "whiped" and cannot be recalled. If you can go into setup-menu, things can be rearranged. There are numerous web-shops where you can buy an orignal remote. I recently bought an original remote for my DVD player. This however was at an on-line shop in Belgium. Just surch for Pilips on line shops in your country. Good luck.
Sep 10, 2014 | Philips Magnavox 20MT133S 20" TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
I don't have my original remote. I want to watch a dvd but the tv is in "S"mode?
Unfortunately, that function is simply too advanced to access any other way but through an appropriate remote control unit. As this is such a highly sought TV by audiophiles who want an excellent listening experience for their older audio-DVDs, this remote control is readily available. One can buy a replacement, either a used original remote (model RCU81B) for between $8- $40 on eBay and other such sites, or brand new, for between $30- $35 through several different remote replacement companies. Simply search the words "Philips Magnavox RCU81B" to locate such sellers. You also have the choice of buying a clone- brand new, of course- for around $20. Most sellers of remotes on sites like eBay do warrant their used products, so there is no real reason not to go that route.
I just ran a quick check of an eBay seller with a $7.99 original remote, and not only does it look great, but it comes with a 100% guarantee. To get full functionality of your TV back, especially for one that offers as options as the TP2784C, that is a very small amount of money to pay. The seller even offers a "Best Offer" option, so who knows, you might try offering him $5 and see if he is willing to go for it!
May 01, 2010 | Philips TP2784C TV
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
Add or delete channels on LXI tv
I have a Phillips LXI 46in TV. How do you save channels?
Jun 15, 2009 | Philips TP2784C TV
No remote, channels locked on smart tv
On this set, the volume buttons are the same as the menu button on your remote. The two channel buttons work the same as the scrolling arrows on your remote. It will take some practice, but to turn on the menu, press both volume buttons at once. Then practice using the volume controls to scroll. Once you have the hang of it, you can simply use these four buttons the same way you would have used your remote. If you cannot figure it out on your own, come back here, let me know, and I will sit down and map it out completely for you.
Hope this helps in some small way!
Jan 30, 2009 | Philips TP2784C TV
Philips magnavox tv, no remote....channels locked
I called Philips at 1 888 744 5477 and they solved my Access Code question thusly.
Default Code is 0711.
Hope I can submit this now, AND that it helps someone.
Need Unlock channels
I called Philips Magnavox at 1 888 744 5477 and they told me the default ACCESS CODE number is 0711. It works on my TV though it didn't solve MY problem of the TV defaulting to Chanel 9 every time I turn it on. Drats. Hope this helps.
Jan 01, 2009 | Philips TP2784C TV
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Philips TP2784C TV Logo
272 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
