Question about aFe 2006 Chevy Trailblazer - SS, 6.0L V8 - Air Filters
2006 trailblazer with 6.0 starter removal - aFe 2006 Chevy Trailblazer - SS, 6.0L V8 - Air Filters
How do I remove the rotors of a 2010 Volvo s80??
There are a couple of S80 vids on utube. Not sure if this one takes the rotors or not, if not there are a couple of others that may.
Jan 07, 2015 | EBC Brakes 2010 Volvo S80 - AWD, 3.2L...
How to change air filter on 2006 Toyota Hiace SLWB diesel automatic?
Hi josephjohn,Here are instructions on How to Change Cabin Air Filter in a Toyota. It is recommended to replace this filter at every oil change.
Jul 29, 2014 | Filter Queen Defender Air Purifier
How do you replace the bulb in a freshair purifier
Make sure you have the starter use with replacement bulb. Usually comes with replacement bulb. Open the back of th unit by removing the cover.
Oct 18, 2012 | Ecoquest Fresh Air Air Purifier
How to clean ozone plates
Unplug the machine.
1) Remove the back screen, then pull out the plates.
2)Soak them in a 1 to 1 solution of PLAIN ammonia and warm water for about 5 minutes.
3)Scrub with a toothbrush or soft veggie brush.
4)Rinse well.
5)Blow dry. Do NOT use any cloth or paper of any kind. Avoid touching the screen with fingers.
6)You can also clean the contact points with a cotton-tipped swab and alcohol.
6)Reinsert plates, making sure that they enter in the "groove" or track, both top and bottom. Make sure the contact fingers press firmly on both sides in the screen area.
Jan 19, 2011 | Alpine Air XL-15 Air Purifier
I have the same problem. I replaced the lamp and starter with new . But after I press the button reset the mesage replace the lamp continue to show it and the blue light is missing (INSIDE THE BOX)with any...
It may be that the bulb and starter are not inserted correctly. The message indicates that something is not making contact. Make sure they are seated properly and firmly. They need to be twisted, like installing a fluorescent light bulb.
If the bulb begins functioning, but you are still seeing the message, push the reset button, then turn the machine off for a minute or two. If everything is installed correctly, the light should work, and the message should be removed.
Jan 14, 2011 | Ecoquest Fresh Air Air Purifier
How to replace your uv light in your fresh air ecoquest air purifier?
1. Unplug the purifier
2. Remove the two screws on the back cover and remove the cover.
3. Remove the two screws on the the top that hold the lint screen and remove the screen.
4. Remove the purification plate by sliding it out.
5. Remove the RCI target plate by sliding it out.
6. Disconnect the purification plate contact lead wires from the purifier plate cage.
7. Remove the two screws at the bottom of the plate cage.
8. Slide the cage forward, lift and remove the cage.
9. Rotate the uv bulb a quarter of a turn and lift it out of the unit.
10. Install the new uv bulb and rotate it a quarter of a turn to lock it.
Perform steps 1-9 in reverse order to reassemble the purifier.
Dec 06, 2010 | Ecoquest Fresh Air Air Purifier
How do I replace the UV lite and starter/
Unplug unit. Remove rear cover. Remove the rear filter assy. Unscrew (CCW 1/4 turn ) the starter. Release the 2 screws on the ozone unit and slide it out about an inch. Reach toward the front of th machine and you will see the UV bulb. Turn it 90 degrees and it will come up out of the slot. Replace and reassemble and stat it up!
Mar 19, 2010 | Ecoquest Fresh Air Living Air Purifier
My Sharper Image Ionic Breeze GP will not power on. One of the earlier posters recommended one to remove the rear grill & clean the "wires". I removed the 4 screws that holds the grill to the body,...
as far as I know there are very tiny screws along the sides of the unit. 4-6 screws. remove and make sure to safely put them somewhere and not loose them. good luck.
Feb 01, 2010 | Sharper Image Ionic Breeze GP (SI730) Air...
Keeps cycling
I would start by changing the little white starter which is inside of it, I believe it's known as the F-5
Jun 22, 2009 | Ecoquest Fresh Air Air Purifier
aFe 2006 Chevy Trailblazer - SS, 6.0L V8 - Air Filters Logo
29 people viewed this question
Top aFe Air Purifiers Experts
Dan Webster
Dan Webster
Pcm2048
Are you an aFe Air Purifier Expert? Answer questions, earn points and help others
