Question about Yamaha RAV285 Remote Control WN058300
How to program to comcast cable box - Yamaha RAV285 Remote Control WN058300
HOW DO I PROGRAM MY XFINITY COMCAST REMOTE
Check here for a list of manufacturer codes for your specific remote: Comcast Cable Remote Support
Check here for a video of how to get into programming mode: Program Your Comcast Remote
Comcast's remote page seems to be broken right now, but may work in the future: Comcast Remote Codes Program Your Comcast Remote Control
Please post back if these don't help!
Dec 23, 2014 | Samsung UN46D8000 46" 1080p 240Hz LED 3D...
How to program my decibel electronics jumbo universal remote to my comcast cable box
I pushed code search different blink appeared pressed tv press code then use on buttons. On all the code
Dec 20, 2012 | Televison & Video
Have just had a Comcast cable box installed and now need the code for the SONY ICF-CD555TV to program the remote. Can none help?
Enter the information and it will give you your codes. I can't do this as I don't know what remote you have.
http://customer.comcast.com/Pages/HelpNFC.aspx?print=false&id=remotes
You should have gotten a folded manual with all of the codes though.
Oct 12, 2012 | Sony ICF-CD555TV 7 in. Portable Television
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
Oct 02, 2009 | Hannspree HT09 28 in. LCD TV
VCR doesn't record since Comcast installed digital box
Try this..Run cable line into VCR in, cable from VCR out to box, then cable from box to TV..this might work...I have done this for YEARS and it is never failed. You can then watch and record 2 things at once.
Feb 12, 2009 | Proscan PSVR72 VHS VCR
Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Dec 01, 2008 | Sharp Remote Control
Closed captions go on and off sporadically
if the comcast box is not hd then the control is with your tv/remote.
If the comcast box is hd, then you can control it from the comcast remote. To do this press cable, then power and in 2 seconds press menu to get to the hidden hd setup menu, scroll down to closed captions and set it to enabled or disabled then press power twice to get back to you rtv
Nov 26, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
Nov 08, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
I got a a sharp LC-32D43U and for my motorola cable box i use hte code 31 from jerrold, i take it from the manual and i got it tryin every single code unti i get one that works.
Hope it works for you
Jul 27, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony Bravia and Comcast MY DVR Not Working Now
Greetings...
Is the Comcast box digital? and is it a Scientific America 8000 series box?
If so, try unplugging the power to the cable box for a minute, replug and after the reboot see if that fixes the problem...
Ed
Dec 14, 2007 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Yamaha RAV285 Remote Control WN058300 Logo
32 people viewed this question
Top Yamaha Televison & Video Experts
Larry Stiles
Larry Stiles
Electro Med Services...
Are you a Yamaha Televison and Video Expert? Answer questions, earn points and help others
