Question about Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
When I turn it on the picture on the right side of the tv as you look at it is double. It usually goes away after 5 minutes. It doesn't do it all the time. Turning it off and then back on doesn't help. It is 4 years old.
3 Suggested Answers
toolkits
  • 1099 Answers
SOURCE: l have a sony 46" Bravia XBR TV it is also almost
All Flat TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times reseating the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, but it is very easy to wreck em.
Good luck.
Posted on Aug 11, 2010
gopakumarg43
  • 75311 Answers
SOURCE: blurred right side of bravia 46 inch tv goes away as tv warms up
Check the T'Con board
Posted on Apr 12, 2012
Samsung LN40A630M1F schematic
Sounds like the Tcon board has an issue especially if its on one side only. It could also be the tcons flex cables connections need to be reaseated.
Aug 04, 2012 | Televison & Video
I have a Sony Bravia KDL-52XBR4 LCD TV.
Sure, but not at minimal cost - it's a sony! Probably the t con board.
Sep 17, 2017 | Sony BRAVIA KDL-52XBR4 LCD TV
Picture and sound going out- flashing lights
the problem its the main board it controls everything if no warranty go to www.shopjimmy.com better prices better than manufacturer and tv repair man
Apr 13, 2010 | Samsung LN46B650 46/49.5 in. LCD HDTV
When i turn my tv on 3/4 of the right side of the
The problem is most likely in the image processor area, or the backplane circuitry on the screen itself.
The service rep would be equipped to properly service your set. You should call LG to find out who in your area is able to service your set.
If the set is out of warranty it could be fairly expensive to service.
Jerry G.
Dec 16, 2009 | Samsung LN-T4671F 46 in. LCD Television
I own a pioneer projection monitor model SD-532HD5. It has been flickering on and off where it goes from its crisp color to a hazy type picture. Yesterday, it flickered and the picture went away...
This TV is known for bad solder joints on the Power board. Call a good TV Tech and have him resolder the Power board. It is on the right hand side of the TV looking from the back.
Jul 30, 2009 | Televison & Video
Double picture at star up
if you have cable telivison try unpluging the cable from wall and tv the replugging it. make sure the connections are secure and also make sure the cable is plugged in straight. or your cable might be bad.
Jan 09, 2009 | Sony KDL-40XBR4 40 in. LCD HDTV
I am getting double images while watching TV;
There maybe some loose components on the circuit and that needs resoldering. Bring it to the repair shop to done.
Dec 02, 2008 | Zenith C27A24T 27" TV
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
TV picture goes out
The tv is shutting down because of a power problem. It could be the power transformer or a color gun overheating. Expect at least a couple of hundred dollars to fix it. Some shops will do house calls for around $65 and can diagnose the problem and give you an estimate. Usually they can just remove the board, take it to the shop and repair it, then reinstall it.
Nov 03, 2007 | Televison & Video
Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
