Bought tv secondhand, not seen working, only presents black and white picture, am I doing something wrong? Apparently only just over a year old.
  • jantaylor319 May 18, 2009
    Oh my god, what's that in English?!
    Sergeant:
    Champion:
  • 201 Answers
Check between settings scam, ntsc pal settings will be found in display settings.
Posted on May 18, 2009
  • Jonathan Van Rensburg
    Jonathan Van Rensburg May 18, 2009
    On your remote look for a menu button or a dispplay button look for settings secam ntc or pal play select between them until you get colour hope this works
What caused picture to disappear abruptly?
hey....don't panic! :-) ...i think your IC responsible for audio-visual has seen it's last days.Just replace that and everything should be normal again.
Nov 17, 2015 | LG 42pa4500 42" Inch Widescreen 720p 600hz...
DVD Playback is only Black & White
Different areas use different colour systems. The most common types being PAL and NTSC. What I think you might have done is changed the colour type setting to one that is not compatible with your TV. If you have the manual look up the colour settings. If you haven't got the manual look around the main menu for them. If all else fails use the factory reset.
Mar 12, 2017 | Toshiba Bdx1200 Blu-ray Disc Player
I have a 5 year old KLH DVD player. I had it hooked up through AV cable to a 6 year old SONY Trinitron 37" TV & it worked fine. I am now trying to hook it up to a new Westinghouse flat screen TV...
double check the wires are in the correct connections on both the tv and dvd player also the KHL dvd player may need to be put in progressive scan. Usually the red wire for video and the one for audio get plugged into the wrong input and causes this issue
Dec 10, 2010 | Televison & Video
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
Cable won't work on new tv
When I plug in all of the cables the tv says no signal. I have tried it on all different input settings and my cable provider tried sending me a stronger signal. Could I be doing something wrong and is there anything else I can try?On the back the tv has no receptor what else is there i can use?
Aug 03, 2009 | Insignia Televison & Video
The lower half of the tv goes black/also pastel colors
yes humidity has been known to make the panel seperate. I live in south tx and work for sony, alot of panels that show that prob is usually the panel seperating. wouldnt recomend to fix to costly around 85% the cost of when you bought it.
Jul 03, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
PS3 image keeps scrolling and is in black and white
I am an Australian ( 240v) and I took my PS3 to the Caribbean (110v - same as the US) and it worked fine as far as power concerned. However as I had the PS3 set to work on my TV back home (PAL) when I took it over there & plugged it in (NTSC) I had a similar problem. I fixed it like this: when the PS3 is turned off hold down the power button for 15-30 seconds it will reset the PS3's settings to defult and it should work on the system that it's connected to. Hope it helps
Jul 02, 2009 | Sony PlayStation® 3 (80GB) Console
Our Color TV is now Black & White
It could be the color wheel and in fact probably is. I've seen them shatter which would explain the noise. They are glass and spinn at 9000 rpm. An involved repair though definatley a job for a pro. It could be worse, probably a few hundred will do it. Was the TV begining to be a little loud before the failure? Could be a sign, i've seen many noisy color wheels.
May 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
View images on TV
Hi again: About the black and white pictures on the TV... not normal I think... I have never seen your camera model but a common thing can happen to any camera!! Have you already tryed to connect the camera to your TV using a AC Adapter (D-AC8 in your case)? Are the connections Ok? You're connecting following the manual instructions? If you don't have it download it... :) http://www.pentaximaging.com/files/manual/OptioS5i_Web.pdf Regards
Sep 08, 2005 | Pentax Optio S5i Digital Camera
Televison & Video Logo
88 people viewed this question
Top Televison & Video Experts
Electro Med Services...
