Question about Evenflo Journey Premier Stroller
Evenflo journey car seat adjust shoulder straps
JMuskovitz
  • 135 Answers
SOURCE: shoulder straps
You can contact EvenFlo directly, they will be happy to help you out: http://www.evenflo.com/ Evenflo ParentLink Department: 1-800-233-5921
Posted on Mar 31, 2007
  • 17 Answers
SOURCE: evenflo aura travel system
I hope this information helps:
1) There are harness anchors (metal clips) located on the bottom of the seat. Push these up through the slot to the front of the seat on both sides. To do this, you will need to pull them toward you, and then turn the anchors to fit through the slots.
2) You should be able to remove the bottoms of the straps at this point. Remove them, then pull the tops of the straps through the slots. (You will need to remove the buckles during this process.)
3) Slide the straps through the slot you need for the correct harness height.
4) Replace the buckles in the correct positions.
5) Replace the bottoms of the straps into the harness anchors.
6) Push the harness anchors through the padding and back into the bottom of the seat. Clip into place.
Posted on Dec 04, 2007
bdlildvl07
  • 3 Answers
SOURCE: evenflo journer
on the back of the carseat the are black plastic holders the straps go threw and there is a part in the middle that you push down and you pull the front staps to loosen or the back straps to tighten
Posted on Jul 04, 2008
SOURCE: How to adjust straps on
You posted this in August so I'm not sure if you figured it out yet. I was loving this system until I ran into this problem tonight especially when I couldn't find this in the manual, but I figured it out. On the back of the car seat you'll see the black thingys that keeps the straps in place, above them are these two clips that you have to push down. push down the clip and pull the black thing up , it will release from car seat and from there you're able to adjust the straps height. I already contat evenflo about not putting this info in there manaul.
Posted on Jan 10, 2009
SOURCE: Evenflo Journey Stroller seat recline question
To recline the seat on the Evenflo Journey Stroller, you have to pull up and back on the handle on the back of the seat.
Posted on Feb 19, 2009
I need to adjust the straps to my car seat to fit my growing baby. I have tried multiple times to thread it through the back, but it will not work! I have tried everything and it seems impossible. Is...
you need to turn the car seat over and on the very bottom there are two gold rectangle-shaped clips holding the straps. You can pop these out and feed them through the hole....not like other car seats where the straps unattach up at the shoulder end.
Nov 01, 2009 | Evenflo Embrace
I have a stroller just like Evenflo Aura Select Stroller - Somerset that one, and i was wondering how you make it so the baby can lay down...
It should have a strap with a buckle to adjust the seat into position by sliding the buckle up or down. Hope this helps.
Jul 05, 2009 | Evenflo Journey Premier Stroller
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
How to adjust straps on the evenflo journey clairmont carseat?
Aug 09, 2008 | Evenflo Journey Premier Stroller
Evenflo car seat
1. Remove the cover on the back upright (8 phillips screws).
2. Remove the white plastic clips that retain the brass clip holding the shoulder straps in place.
3. Pull the brass clips away slightly, then, turn them and push through the slot where the shoulder straps go through to the front of the car seat.
4. Pull the straps through the lower seat cushion slots.
5. Wash and reverse steps above to put back together.
Jul 27, 2008 | Evenflo Generations
Evenflo Discovery 5- Pink and green
you need to take the seat to the dealer for safty reasons
Mar 31, 2008 | Evenflo Discovery - Midland Blue
Evenflo journer
Feb 17, 2008 | Evenflo Journey Premier Stroller
Evenflo aura travel system
Dec 04, 2007 | Evenflo Aura Traditions Travel System...
Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Jul 31, 2007 | Evenflo Embrace - Rainforest
Shoulder straps
Mar 31, 2007 | Evenflo Aura Traditions Travel System...
Evenflo Journey Premier Stroller Logo
26 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
