How to open ve holden commodore glove box
Hey i wana change my ve commodore glove box key lock but to do this i have to open the glove box
  • 1779 Answers
SOURCE: 2000 Toyota Corolla VE -- Glove Box Stuck
The most common cause is something inside the glove box jammed in the latch. Push glove box door release , and GENTLY insert a flat putty knife, plastic knife, or similar type tool in the groove of door, GENTLY try to pry open the door. U will probably (hopefully) find a napkin, map, or glove (does anybody actually put gloves in the glove box?) jammed in the inside latch. Let me know how u make out.
Posted on Nov 02, 2008
erikp22
  • 136 Answers
SOURCE: hey i changed my car battery and i need the radion
take vin code straight to holden dealer .they'll have it on record.
Posted on Jun 21, 2010
t_aforrester
  • 93 Answers
SOURCE: how to change cool'nt in a VE commodore holden
to change the coolant in any engine you need to firstly remove the bottom radiator hose when the engine is cold not when the engine is hot and drain the whole system.
You then need to get some coolant from your local supplier and it will tell you on the container the proper ratio of water to cool it. Once you have put to cool it in top up the system with clean water.Regards
Posted on Feb 19, 2012
johnjohn2
  • 5763 Answers
SOURCE: 2005 slk350 glove box is locked. how do you open it.
This is a common problem with these cars, the glove box has a solenoid that locks and unlocks it, this is the problem, you will need to lock and unlock the doors with the door button not fob, you will need to do this several times until the glove box unlocks.
This sounds like yours is on the way out but if you lock and unlock a few times you should be able to get it to unlock, you may have to do this a few times, i know its time consuming but the lock will unlock.
When you get the glove box open, there are two reasons for this problem, first it may just need a little wd40 sprayed on the latch and arm, or the solenoid is bad.
The way to figure this out is with the box open spray solenoid arm and latch and then hit the lock and unlock a few times as you watch to see it move, again you may need to hit lock and unlock a few time to get it moving, once moving you will see the movement and then spray a little more, If the WD40 works then the latch will move with door locks but if you still get get the latch to move then you will need to replace the solenoid.
The last thing may be a relay, there is a relay that controls the latch but most times its latch or wd40 being the problem.
There are TSB"s on this problem and if you bought this car from the dealer i would see if they would repair it at no cost to you, its worth a try.
Posted on Jun 30, 2012
  • 51221 Answers
SOURCE: 2004 cad deville glove box is locked and the key cylinder is gone,how do i open the glove box door
Look in the hole and see if there is a slot ir a bar . Put in a screwdriver and turn if a slot or get a pair of long nose pliers and turn the bar.
Posted on Mar 10, 2013
I have a v6 ve commodore with a HBE engine can I put a HBE engine in it what is the diffrence Ta garry
yes possible
will create electronic miss- matches to be sorted
Holden Commodore VZ VE V6 Alloytec Motor Engine HBE engine code AUD 1 250...
best ve commodore owners forum around
https://forums.justcommodores.com.au/forums/ve-holden-commodore-2006-2013.75
Apr 30, 2017 | Cars & Trucks
Where is the fuel filter located on 2007ve holden commodore
filter is within fuel pump module in tank. Unless you are a mechanic advise take it to Holdens. Not an easy job rear sub frame has to be lowered. A lot of work involved and it may not be your the filter causing the fault.Get a proper diagnosise it may save money in the long run. you can always get a quote 1st.
Feb 05, 2017 | Holden Cars & Trucks
VE. How can I remove seat belt retractor panel?
Vehicle specific issue. I suggest you go here and the guys on the VE forum can help you with that........................
Forum VE Holden Commodore 2006 2013
Apr 19, 2016 | Holden Cars & Trucks
How master reset radio code in a vt
almost all cars, are the same rules. here,
who can help varies by unstated country so here generic answer.
we call this bricking (rad or nav , dumb as brick)
http://www.fixkick.com/power-elect/Keep-Alive/keep-alive.html#radio
the other answer in in the glove box.
open door, take out book see radio. chapter
it says go to dealer.
today, here in USA we have vast numbers of key shops that get rich of this bull.
YMMV
YRMV your radio may vary
Jul 08, 2014 | 1998 Holden VT Commodore
How to change cool'nt in a VE commodore holden
Feb 19, 2012 | Cars & Trucks
How to fit a tow bar to a ve commodore
Jan 28, 2012 | 2006 Holden Commodore SS
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
