Wan nien 101v0 - Computers & Internet
Can the management IP address of an ONT be configured?
ONT management IP addresses are classified as LAN-side management IP addresses and WAN-side IP addresses.
· The LAN-side management IP address can be configured. To do so, choose LAN > LAN Host Configuration from the main menu on the web page.
· The WAN-side management IP address is based on WAN port configurations.
§ If the WAN port statically obtains an IP address, the WAN-side management IP address can be configured. Ensure that the configured management IP address can communicate with the upper-layer device.
§ If the WAN port obtains an IP address in DHCP or PPPoE mode, the WAN-side management IP address can only be obtained from the DHCP server.
May 16, 2016 | Computers & Internet
Cisco 861 behind Wimax Router from ISP
> WAN IP: 44.55.66.777
> ISP Router LAN IP: 111.222.333.174
> Cisco Router WAN IP: 111.222.333.175
Really? Each "octet" must be a value between 0 and 255, inclusive. A value such as '777' is not valid
Aug 27, 2012 | Cisco 861 Router
My wireless wont turn on on my dell d600
PLEASE CHECK IN DEVICE MAMAGER IF WAN CARD IS DETECTED OR NOT IF IT IS NOT UPDATE THE LATEST WAN DRIVERS FROM SUPPORT.DELL.COM IF IF STILL NOT ABLE TO DETECT GO TO SUPPORT SITE SEARCH FOR MANUALS OF THE PRODUCT RESEAT THE WAN CARD AND TRY IT AGAIN , IF STILL NOT WORKING WAN CARD HAS GONE BAD CHANGE THE WAN CARD ,
IF WAN CARD IS DETECTED IN DEVICE MANAGER JUST UPDATE THE LATEST DRIVERS AND TRY IT AGAIN AFTER RESTARTING THE COMPUTER ,
May 14, 2010 | Dell Latitude D600 Notebook
2000 S-10 blazer will not start
1 check connection check the battery cables are clean and tight nien. 2 Check the negative cable is connected to the engine this 3 Check the starter relay. Check the switch trasmision
Feb 03, 2010 | 2000 Chevrolet Blazer
Problem with RV042 linksys router
Ah Wan 2 doesnt like to receive a DHCP address you will have to get static Ip addresses
Jul 11, 2009 | Linksys RV042 VPN Router
No wan light
If no wan light bypass the dlink router and check if ethernet cable connected to wan port is working. Once you are able to go online through modem connect cable to WAN if light does not go on log into oruter and clone mac address and save settings.If doesnt work powercycle router and turn modem on first then router next if doesnt work upload latest firmware.
Sep 05, 2008 | D-Link AirPlus DI-524 Wireless Router
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
WAN 2 dissconnects
Try check with your subnets, if your subnet on your SBS is the same as your Xincom configuration and both your SBS and XIncom is acting as a DHCP server, it might cause a conflict.
Jan 19, 2008 | Xincom XC-DPG502 Router
WAN requests
The feature you are referring to "Block Wan Requests" is either enabled or disabled In the pane to the right, where there are 4 subcategories to "Block Wan Requests", Block Anonymous, Filter Multicast, Filter NAT, and Filter IDENT. These 4 subcategories are your choices for blocking WAN requests. They can be either enabled, or disabled.
Nov 25, 2007 | Linksys Wireless-G WRT54G Router
WAN settings
The WAN settings should be configured by Verizon personnel only. If you reset the VDI-604 or VDI-624 to factory defaults, you will need to contact Verizon to reconfigure your WAN settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
518 people viewed this question
David Payne
David Payne
