Question about Bose Wave Radio
Cannot connect aluratek aiso1f blue tooth devise
I am attempting to use Bose AE2w wireless headphones using an aluratek aiso1f device, will it work and if so how do i connect it
3 Suggested Answers
SOURCE: My Bose Quiet Comfort Headphone Cord
Go to
http://www.bose.com/controller?url=/shop_online/headphones/noise_cancelling_headphones/accessories/qc3_replacement_audio_cable_acc.jsp
It even comes with free shipping
Posted on Jan 05, 2009
wiqi546
  • 1511 Answers
SOURCE: Regardless of the audio source I connect my Bose
Hello and Welcome to FixYa!
Yes Sir, as you have cross checked the audio so other possibilities have been ruled out, the only problem can be with your Head Phone unit, usually what happens is somewhere from inside the wire get cracked, or short resulting in noise or static, so the solution is to replace the wire, but the unit is a delicate thing so I'll never advice to D.I.Y.
I hope you have a clear picture now,
Regards, Waqar.
Posted on Oct 10, 2009
My p.c does not get any drivers for my sansui bluetooth headphones.
If you have other blue tooth devices working correctly, do a search for new devices on your blue tooth software. Pair the headphones using the blue tooth software.
Jul 15, 2015 | Audio Players & Recorders
How do I connect an sbt-105 bluetooth headset to my computer(or is it even possible)?
Does your PC have blue tooth enabled? It may need a blue tooth dongle in order to see the headset
Aug 21, 2014 | Samsung Att Captivate Glide Over The Head...
Can I connect to Vizio TV with blue tooth
If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
May 24, 2014 | AUVIO Bluetooth Headphones
How do wireless headphones work
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
Feb 15, 2014 | Sony Audio Players & Recorders
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
Feb 22, 2011 | Plantronics Backbeat 903 Bluetooth...
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Bluetooth not working in sony W580i phone
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
Problems with Bluetooth
Just download the drivers of blue tooth on your notebook correctly man.
then spam me if it wont work cuz i tell you what the next solutions ok.
Oct 20, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Blue tooth adapter
Connect the headphones to the bluetooth.
Open the control panel, go to Sounds and Audio Devices.
Click the Audio tab.
Under Sound Playback (top portion of the tab), it says 'Default Device'. Drop the menu down and select your headphones. Click apply then ok, and you should be good to go.
I can't guarantee that this will stay set up this way. If you disconnect the headphones, you very well may have to run through this again.
Apr 27, 2008 | Computers & Internet
Bose Wave Radio Logo
16 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
