Question about Mitsubishi WD-65C9 65" DLP HDTV
WD 65 c9 shuts down and orange light blinks
TV shuts down completely and an orange light continually blinks steady
  • 1030 Answers
SOURCE: mitsubishi wd 52525 dlp shuts down
mitsubish has issued a service bullietin about the problem. which means ussally they will pay for its repair. the reson it says airflow bock is that there is a temperture sensor that is at fault... it needs replaced.
Posted on Dec 13, 2007
rylee_smith
  • 8619 Answers
SOURCE: MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 20, 2009
sethdileswar
  • 253 Answers
SOURCE: Mitsu WD-62725 green light blinking continuously.
pls check remote aur repair smps power supply of tv
Posted on Apr 05, 2010
SOURCE: WD-62327 Lamp
OSRAM VS. PHILLIPS
This is about buying replacement bulbs for the WD62327 TVs.I dont know about the other models but I purchased a PHILLIPS replacement bulb and it worked for about a week and then those dumb flashing lights and no TV. I did some research and others were saying that you had to replace some condensers. Shop would do it for 600 dollars..Well i sent the bulb back and bought an OSRAM replaement bulb. The TV is now working perfect.
Posted on Jul 14, 2010
SOURCE: Red blinking status light on DLP Mitsubishi TV
how do you get the tv back on when the light keeps flashing
Posted on Sep 10, 2010
Mitsubishi dlp wd y65 orange light blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 07, 2016 | Mitsubishi WD-Y657 65" DLP Projection TV...
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
I hav a mit 65 in tv model number wd 60737 it comes on with the words welcome mit and green light blinks and then shuts off.
Does the led light flashes green continually?
Check if you can access the operational error code. The TV must be in shutdown and then press the front panel "activity" and "channel down" at the same time and hold them for 5 secs.
Led light will flash 2 digit code separated by a pause.
23 - 2 blinks pause 3 blinks
Let me know the result...
Nov 16, 2011 | Mitsubishi Televison & Video
First blinking green light tv would turn on for a few minutes then turn off, pushed reset button and unpluged but problem would continue now theres no sound no picture and just a steady red light. Please...
The red light is indicating the set has shut down for a specific reason. You can dtermine the reason by going to the sets front panel and pressing the menu button and the device/input button both in together and hold for 6 seconds. The light will switch and begin to blink a series of blinks( First number) and pause briefly then blink another number of blinks (second number) then it will repeat that same two digit blink code. Let me know the code and I will let you know what happened to shut the set down. Respond to this same post for assistance.
Aug 12, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I replaced the lamp for TV but the orange light in front of TV is still blinking and I can not turn TV on.
kimhean,
It sounds like you may have to reset the lamp timer. Here is the procedure:
Hold down the two arrow buttons and the Power button on the control panel at the same time for 3 seconds. The status indicator will blink twice. The timer will be reset to zero hours.
Thanks for using FixYa and the generous rating.
hardrocko
Aug 20, 2010 | Mitsubishi WD-65731 65" HDTV
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
When i turn on my 64inch mitsubishi wd 65733 tv it stays on for about a min (WITH PICTURE AND SOUND)then it just shuts off with the (orange) status light steady and the (green)lamp light blinking. I cant...
My concern is that the new lamp may be having an issue and not able to hold the high voltage.
If the old lamp was working, I would try this old lamp again.
If this issue was with the old lamp also. Then there is something else wrong either in the power supply or the lamp ballast where it isn't able to continue to put out the high voltage.
More than likely a lamp issue!
A/V Media Tech Guy.
Feb 02, 2010 | Mitsubishi WD-65733 65" HDTV
I have a wd65733....When I turn the set on, I get a picture then about 30 seconds later it will shut down giving me a steady orange light
CK Lamp and Lamp Fan, Mats has Lamps for $99.00
other companys want 273.00 1-800-628-1118
Encompass Parts Distribution has Free service Manual for this Model, you can print out online.
Sep 13, 2009 | Mitsubishi WD-65733 65" HDTV
Mitsubishi WD-65C9 65" DLP HDTV Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
