Question about Beverage-Air BM23
Beverage-Air BM23 cooling
I have an older used Beverage-Air kegerator # BM23. I have the thermostate turned up as high as it will go (1 - 9) and I have it on #9. I have a thermometer in there and it shows the temp @ only about 40 - 42 degrees. It also seems to run all the time. I would like to get the beer a little colder to 34 - 35 degrees. Does this unot need a recharge? I have cleaned out all the duct from the coils. Thanks for the help.
2 Suggested Answers
  • 1253 Answers
SOURCE: my BM23 beverage air kegerator runs constantly and
I would definately start there. That is what contols the cycling of the compressor.
Posted on Jan 30, 2011
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
How do I get the right temperature in a beverage air BM 23 Kegerator
either a problem with the thermostat or the probe for it has been dislodged and getting a false temp reading
May 18, 2014 | Beverage-Air BM23
I'm trying to find out the age of my Beverage Air BM23 Kegerator. It's serial number is #823620I.
Scott,
Your Beverage Air Kegerator model BM23 / serial: 823620I - that serial didn't bring anything up when I called the manufacturer but based on the first 2 digits of the serial and the roman numeral 1 at the end of it - it would appear that your unit was manufactured in 1982 (If that number was on a metal tag then it defiantly was 1982).
We specialize in cooler gaskets and can help you locate the gasket part your unit needs. We also are able to get many other hardware and accessory parts for Beverage Air units and other manufacturers. Let us know if we can help.
Matt at coolergaskets.com
orders@coolergaskets.com
855-288-2259
Aug 25, 2013 | Beverage-Air BM23
Beverage Air Kegerator Runs constantly gets too cold
yes sounds like a bad defrost terminator or timer?
not allowing it to go into defrost so compressor runs all the time and it frreezes up
Apr 29, 2013 | Beverage-Air Refrigerators
Refrigerator not cooling
http://www.beverage-air.com/Main.aspx?pid=57&tab=58
go to this web site and find your exact manual. If you have any questions drop me a line
May 14, 2010 | Beverage-Air BM23
My bev air bm23 kegerator wont cool. the fan works like it is suppose to inside 24/7. The fan outside works as well. There is a hhhmmm sound and then a click. It thought it was the compressor so i took the...
Yes replacing the relay may fix the problem. You want to replace all the start parts. Overload, relay, and capacitor if one is present. Your unit is probably 1/3 horse power or less. You may be able to install a universal 3N1 starter from Supco, rated at 1/4 -1/3 H.P. If new start gear does not fix the problem you may need a new compressor.
Nov 05, 2009 | Beverage-Air BM23
I have a BM23 Beverage-Air kegerator. It was working great until a blackout last week. I had a surge protector on the unit, but ever since then, the temp. would stay around 48-50 degrees. I had an...
electrician do one thing, electricity. If the unit cools, the compressor is running. a power outage should not put the compressor in a "Weaken" state. I would check the starting components. don't overlook your surge protector causing a voltage drop. try running the unit without the protector.
let me know if I can be of any further help.
Mar 14, 2008 | Beverage-Air BEVBM23 Commercial Beverage...
Beverage-Air BM23 Logo
124 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
