Question about Cameras
Remote control not working
Remote control inoperative.Have fitted new batteries but still no use
  • 4234 Answers
SOURCE: PANASONIC COMBO TV DVD VCR,REMOTE
You can try replacing the remote receiver inside the set. This should be a small silver box located in the front of hte set. It should have 3 leads soldered to the board. The part number is:
LSSZ0004 and costs about $5.
Dan
Posted on Jul 03, 2008
robshow
  • 367 Answers
SOURCE: 2004 KIA Optima
Check the fuses for these items they could be blown.
Posted on Jan 07, 2009
  • 267 Answers
SOURCE: TV remote control is inoperative
REPLACE THE REMOTE
Posted on Mar 27, 2009
Molson02536
  • 3854 Answers
SOURCE: 95 s10 blazer 4dr power door locks inop, new
1. Locate the red two wired programming connector located near the central locking control module that is located behind LH Lower instrument panel. Drop the panel and you will see the red programming connector that is not connected to anything.
2. Inside the Red programming connector you will see to pins..
Jump two pins with a section of wire.
3. System should now lock and unlock doors to indicate vehicle has entered programming mode.
4. Press any button on keyless remote once. System should now lock and unlock doors indicating the keyless remote has been programmed.
5. Repeat step 4 to program other remote.
6. Remove jumper wire from programming connector to exit programming mode.
7. Test Remote(s)
Posted on Dec 22, 2009
SOURCE: TV works but won't operate with the remote control. New batteries in remote control fitted.
buy a universal remote
Posted on Dec 09, 2011
Why doesvolume goes up and down by itself
your tv has a faulty infra red remote control sensor which is easy replaced
Sep 02, 2014 | LG 32LG30 32 in. LCD HDTV
Panasonic tv model tc-p42c2 remote is inop
It is a common thing that all the buttons of a universal remote control might not work, as it meant to be. Try an other code. If this too won't help you, there is no other way than buy a new original remote control for your Panasonic TV. You can buy in from the authorized service center for Panasonic at your town. Just give them the exact model number to your TV. They will provide you the original one.
Jul 20, 2012 | Panasonic TCP42C2 42 in TV
95 S10 blazer 4dr power door locks inop, new battery installed in remote, all fuses good, still inop?
7. Test Remote(s)
Dec 22, 2009 | 1995 Chevrolet Blazer
Wii Remotes will not resync after using friends Fit Board
there is a flap in the wii open it up. open the spot where the batteries go on the controller. the controller and the wii should have a orange butten press them both at the same time.
Aug 20, 2009 | Nintendo Wii Console
Direct TV remote, changed batteries, does not work
Ok, simple problem and solution. You had the answer right here. If you take the original battery and put the + end of it next to the new battery + end you will see that the old one is longer for certain. inside the controler you will see the + contact is a coiled wire contact. If you take hemostats, tweezers or needle nose pliars and gently pull the center of the contact out it will spring the contact out of the housing and when you reinstall the new batteries the + end of the battery will now make contact with the wire. Took about 10 seconds to pull this out and my controller now works like a charm. Good Luck.
Feb 28, 2009 | RCA DIRECTV Satellite Remote Control
Remote control no matter what you press toggles 32/33
I cleaned all contacts with alcahol, then I found the batterys were not connected and stretched the ground spring to compensate, and the remote is working fine.
Thanks Joe (Starzu)
Sep 08, 2008 | Televison & Video
Cameras Logo
336 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
