Question about Universal SUICEN SX-948C Bluetooth V2.1EDR Class 2 Handsfree Headphone Headset - White
I have the sx-948c Bluetooth headphones, how do I get it to pair with my iPhone 4S?
I played with the buttons and got the light to flash red then blue and it connected fine, I can't remember witch buttons I pressed, I now want to connect it ti my daughters iPhone 4 what do I do?
I have a pair of Auvio colored Bluetooth headphones and i am unable to use them via bluetooth and reseting doesn't work and i cant find the headphones on bluetooth.
The poorly written manual says to hold the Play/Power button for five seconds at which time you will get the blue light, Then hold the Play button again for three seconds to enter the bluetooth pairing mode at which time you will see the alternating red & blue flashing light. Ignore all of that and just hold the Play/Power button for however long it takes to start the red and blue flashing sequence. That means the headset has entered the bluetooth pairing mode. Then make sure whatever device you are trying to pair has its bluetooth pairing mode activated and you will eventually see Auvio BTCHP on your device's pairing window. Select it and you should then be paired.
Apr 29, 2017 | The Audio Players & Recorders
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
Apr 09, 2014 | Brookstone Big Blue Live Wireless...
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
My ipod bluetooth is on but I can not get my Sx-948c headphones to wireless connect.
YOU HAVE TO POWER ON YOU HEADPHONES , THEN SEARCH FOR IT IN YOUR IPOD THEN CONNECT ,
Oct 23, 2013 | Universal SUICEN SX-948C Bluetooth V2.1EDR...
Plantronics K100 will not pair with iPhone 4S
Is the multifunction button on the K100 allowing it to go into pairing mode? With speakerphone turned off, activate Bluetooth pairing mode by pressing and holding the Multifunction button to turn on speakerphone. The LED flashes red/blue to indicate pairing mode.
Jul 07, 2013 | Radio Communications
My iphone 4s can not find my 903
Once you make your iphone discoverable, then put the Plantronics 903 headset into pairing mode by pressing the power button until it flashes red and blue. If it's not flashing red and blue, it's not in the pairing mode. Below is a link for the user guide which has the pairing instructions:
Plantronics BackBeat 903 Pairing Instructions
Good luck from Headsets Direct!
Nov 25, 2011 | Plantronics Backbeat 903 Bluetooth...
Backbeat 903 I tried to pair them but they don't with my g1
1. turn off the headphones
2. turn on bluetooth on g1
3. hold down the power button on headphones until u see the red and green light flash back and forth. (may take 8 seconds or so)
4 search for devices on g1
5. pair them. if it ask for code it... 0000 (4 zeros)
Nov 16, 2009 | Altec Lansing Audio Players & Recorders
Can't pair TDK BT-100 headphones to my Iphone
I managed to pair the device after plugging the bluetooth headset into the USB power slot. Then I press the main button for 5 secs until the red light started flashing very rapidly and I typed in 0000 and the headset paired off with my Iphone. Good luck
Aug 19, 2009 | TDK Audio Players & Recorders
Pairing the insignia bluetooth wireless headset with an ipod
Perhaps either its pairing log is full, thay hold a number of pairing internally, and may need to be cleared to make room for another....or the headset may need to be reset, either way...heres the scoop....to clear the pairings hold the track forward/track backward buttons down together until the light flashes Purple....Empty pairing log......
If not then try pluging in the set to the charger and holing the 2 volume buttons down the same way..this will shut it off and reset it if it went a bit screwy on ya.... Merry Christmas
Nov 05, 2008 | Insignia Bluetooth Wireless Headphones...
Lost instruction book
go on ur phone and go 2 bluetooth pairing. before u click pair, turn on ur headphones and hold the multi function( button w/ play button and phone symbols) button until flashes blue and red lights simultaneously. once flashing, enter and start bluetooth paring on ur phone. the code is 0000. enjoy using ur bluetooth.
Oct 18, 2008 | Insignia Bluetooth Wireless...
Universal SUICEN SX-948C Bluetooth V2.1EDR Class 2 Handsfree Headphone Headset - White Logo
Top Universal Radio Communications Experts
eradiostore
eradiostore
Sean Ware
Level 1 Expert
Mario van Limburg
Mario van Limburg
Are you an Universal Radio Communication Expert? Answer questions, earn points and help others
