Question about Tablets & eReaders
Samsung tablet Im having problems with my Tablet charging. It will be on 100% but then when I look away and look at it again it will be around 5% to around 15%. Then I will put in my charger, and it will shut down and the blue battery bar will say it's on 100%. So I turn it on and it will stay on 100% for a second, then repeat. Another thing that happens is when I put my charger in and the lightning blot will have a dash through it saying it's not charging. I dont put the cord in a computer or anything, I always put it in an outlet. Please help :(
You may set it back to factory settings .most of the time you can hold down the volume and power at the same time for about 10 seconds until it goes to a screen that gives you options on how to boot. or just try to do it by going to settings.
Posted on Dec 28, 2013
SOURCE: Power port on le1600 does not charge batteries.
We contacted Motion about an issue with our docking station because our power & USB ports stopped working, or worked only intermittently. We were instructed to remove the front cover from the docking station to check the connection of the cables. We found that the cable had completely disconnected (it had evidently pulled loose from tilting the dock up and down). Once the cable was reattached, and the cover reassembled, viola! Success!
Posted on Nov 23, 2009
MalKontent68
  • 748 Answers
SOURCE: THE TABLET BATTERY DRAINED DEAD NOW IT WONT POWER
Have the power adaptor checked by an electrician, most probably you will need a replacement.
If you establish that the adaptor is working, then something happened to the battery charging circuitry in your Asus and it will need repair.
If it's still under warranty, then you are good, otherwise it would be better if the adaptor alone failed, as replacement adaptors are rather inexpensive compared to laptop repairs.
Posted on Dec 31, 2009
Testimonial: "thankyou"
wellanny
  • 70 Answers
SOURCE: Gateway M285 Laptop battery will not charge
discount laptop battery,here you may get your answer.
Posted on Jan 11, 2010
em_br_dj3
SOURCE: I HAVE A PANDIGITALSTAR ANDROID TABLET WHEN I TURN IT ON IT STAYS ON THE WHITE SCREEN AND SAYS PANDIGITAL WITH THE BLUE DESIGN BUT I HAVE NO ICONS AND WHEN I PRESS THE BUTTONS AT THE BOTTOM NOTHING HA
had same problem. I figured it out. While pressing the home key on the bottom of the tablet, press the on/off button until a black screen appears with green words on the side, which says upgrading...please wait...wait. It should take you to the Pandigital screen with a small bar underneath it with green going across. It should work.
Posted on Jan 18, 2012
SOURCE: no power
I had the same problem! It's not your charger, it's the tablet.
Most likely, the soddering came apart on the inside of the tablet, on the part that connects the charging port with some important wires. You can either take the cover off and fix it, but if it's like mine, it'll just come apart again.
This is what i did: plug in the tablet, and cross the cord from the right across the screen, to the left, and make sure it's tight. I use a binder clip to make sure it stays and charges.
Now try powering it up....that should work :)
Posted on Dec 13, 2012
My tablet won't even charge or turn on
it's a factory thing, all You need to do, is open your tab, remove the battery cable for about 10 mins and plug it back again, unplug the screen from the motherboard, and charge it for about, two hours, then plug back the screen connector, and turn it on, if you see it works, turn off the tablet again, and plug in the power cord again, you'll see the charging animation starts, leave it charging for the time you think it's necessary to reach 100%, unplug the cable and turn it on, your tablet is alive, the only problem I've found about this, is that you'll need to turn the tablet completely off whenever you want to charge it, and finally this, VERY IMPORTANT! When your tablet is below 15 or 10% battery, charge it, because if you let the battery die, probably you'll have to do all the steps again.
You need more help give me a call at 1800-204-4427...
Sep 13, 2017 | Tablets & eReaders
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
My tablet wont turn on or charge
Unplug the Battery, hold the Power button for 10 seconds to discharge any capacitors, Plug the battery back in, Charge the tablet until the battery reaches 100% (Factory Charger preferred), Turn it on. If this doesn't work it could be a bad battery, bad charger or bad USB connector.7 Jan 2014
SOLVED: Why won't my tablet charge or turn on? - Samsung Galaxy ...
https://www.ifixit.com/Answers/View/.../Why+won't+my+tablet+charge+or+turn+on https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=My+tablet+wont+turn+on+or+charge
not saying any off this is going to work for you but read it anyway.
the reason i say this is because i had some one else with the same problem but it ended up it was the tablet itself was faulty.
Nov 29, 2016 | Tablets & eReaders
The charge dock on tablet broke so we can not charge tablet can it be fixed? We just got it this October.
Juello. Did some research on your tablet at Amazon, (http://amzn.to/1xWx6S5) and see that they also have an AC charger (AC charger adapter with a 3.5mm power jack and delivering 5VDC 2A). Available for $5: iRulu Black AC Home Wall Adapter Cable Charger for Tablet PC 5V 2000mAh or a there's a nice replacement KB and cover: iRulu New Portable 10 1 10 5 Android Tablet USB Keyboard Case Black . I would guess the connector snapped off inside the tablet, so you will have to remove it with some tweezers. If the pin for the AC adapter broke off inside the tablet, that's a problem, but most everything can be charged from the USB port too see this website:
How To Charge Samsung Galaxy Tab 2 Via USB Port On Computer Laptop PCNEXUS (Samsung used as an example). GL
Jan 08, 2015 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Charge always 100%
Charging and the like are common problems on android tablet. Look for and turn on the Manufacturer's User interface. It should be under settings under samsung menu... or something similar. Good luck.
Jul 20, 2014 | Samsung Galaxy Tab Tablet PC
My Samsung galaxy tablet 7.0 died out while im playing a game, when I tried to recharge it a battery icon with caution sign show up. It does not recharge anymore. Tried another charger of my other Samsung...
Connection on tablet from charger to battery is not being made and that is why it is not charging in one unit but charging in other. Till problem is resolved charge battery in other working unit.
Aug 28, 2017 | Tablets & eReaders
My Samsung galaxy 10.1 tablet will not charge. It keep flashing between an empty battery symbol to a flashing yellow battery symbol. going Off and On. I can not get it to turn on at all. Im pretty sure...
Hi my Samsung galaxy tablet is flashing icon on and off signal but not charging? I have tried turning off for 30seconds still dead what should I do?
Jul 30, 2013 | Samsung Galaxy Tab Tablet PC
Tablet making weird noise
you might have a deffective battery, which is a very common problem to tabs... especially if your using a generic tablet....
Jun 25, 2013 | Wacom Intuos3 6x11 Tablet PC
Tablets & eReaders Logo
288 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
