Question about Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher
Whirlpool Gold Quiet Partner IV does not clean dishes
Does not clean like it used to and to and the tope rack does not get cleaned at all
  • 171 Answers
SOURCE: whirlpool gold quiet partner iv will not turn on
Hi chrslndsy,
I'm Harvey the Master Plumber.
Your problem is: whirlpool gold quiet partner iv will not turn on there is no sign of life in it at all.
Usually this indicates that the power is disrupted. First check the breakers. 9 times out of 10 it's a broken, loose or burnt connection in the d/w junction box. It's located underneth the d/w behind the kick plate on the right or center, depending on model. Turn the power off at breaker and remove cover. Take each wire nut off and repair/replce as nessessary. Test before you close it up.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 13, 2008
wiringlunati
  • 576 Answers
SOURCE: whirlpool du1055xtsq 3 not cleaning top rack of
In my experience, you probably have a clog in the spray arm/arms for the top rack. Take the arm(s) out and see if the holes in them are clogged. Rice, plastic wrappers, and glass from dishes that broke in there are the most common culprits I've seen.
Posted on Nov 25, 2009
  • 52 Answers
SOURCE: We have the Whirlpool Gold quiet partner III
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
Posted on Jan 06, 2010
SOURCE: Wet dishes
I have a whirlpool Gold Quiet Partner Gold and when I turn on to wash, the timer says 81 minutes, it runs for a long time and goes to 71 min and runs and runs and runs. It will go down to 47 min and again will run and run. It doesn't seem to get hot like it used to and dishes are wet when all done.(It can run for hours) Thanks
Posted on Apr 05, 2010
SOURCE: Whirlpool DU1055XTSS Quiet Partner 1 is not cleaning top rack
the sprayer is clogged with ****. I had the exact same problem. my mother-in-law gave me of some 80 year old man that has fixed appliances all his life. Ten minuets after he got to the house it was fixed. cost $70.00. He just took a couple things apart dumped out the **** inside the parts and put it back together. Hope this helps.
Posted on Jan 07, 2011
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Clean filter module whirlpool du900pcdb0
go to the next web how to proceed for clean the filter:
http://www.ehow.com/how_12140731_clean-filter-whirlpool-gold-quiet-partner-iv-dishwasher.html
May 08, 2012 | Whirlpool 24 in. DU900PCD Built-in...
Jun 02, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
I have a whirlpool gold dishwasher model Quiet Partner 3. The top rack is not cleaning the dishes very well. We live in the country and have hard water. I am wondering if there could be a buildup of some...
if it is just affecting the upper rack i doubt it is just a plugged spray arm (though i could be wrong). more likely than not you have a blockage on the intake of your spray pump motor. a series of bones, toothpicks, foreign material, etc could be blocking the entrance of the pump causing it to starve for water so to speak.
you will more than likely need to remove the lower rack and spray arm to be able to disassemble the strainer and gain access to the sump.
a complete model number would help bunches to.. alas
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our quiet partner iii dishwasher is not working. It is not gettting dishes cleaned soap left on dishes
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
May 16, 2010 | Dishwashers
The dishes coming out dirty on my Whirlpool Gold Quiet Partner IV. Cycle seems to complete. The soap is being used. Not sure how old it is ... it came with a house I just bought. Any suggestions?
Clean the jets on the unit. Jets are the small openings the water comes out of. Contact Whirlpool, follow their recomondations, or add some CLR or Lime Away to the washer without a load of dishes. Both products remove Calcium Lime and Rust deposits which impede the flow of water, causing your dishes to come out dirty
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
Wet dishes
Hello
The heat dry button must be lit up or you are using air dry instead!
ican
Please leave a rating before you leave
Dec 10, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishes not clean in bottom rack of Whirlpool Quiet Partner I (du1048xtps4)
check to make sure your lower spray arm openings are not blocked.
Nov 07, 2008 | Dishwashers
Whirlpool GU2700XTSB / GU2700XTSQ / GU2700XTST Built-in Dishwasher Logo
19 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
