Question about Xerox Phaser™ 6115MFP/N All-In-One Laser Printer
Hi i am having a few problems with me xerox paser 6115MFP all in one, every time i want to scan or print i need to restart it. also now we have a juge paper jam that we can't take out please help!
  • 2 more comments
  • hagitfa May 18, 2009
    hi
    thanks for the answer but the device is not conected to my computer, rather it is wireless
    what do i need to do?
    Hagit
    what about the paper jam that i can't reach?
  • hagitfa May 19, 2009
    hi
    thank you. do you have instructions on how to remove unremovable parts inside the machine? it is in one of the places i can't reach
    thanks
    Hagit
    not so much
    Novelist:
  • 130 Answers
If the paper jam is not reachable try pulling out if possible with some flipper clips.but if its very much internal then dont try as u may damage rollers where the paper is stuck.In that case you will have to open the printer and get access to rollers and get the paper removed.
thanks and please do not forget to accept the solution.thanks for using fixya.
keep updated...
Posted on May 19, 2009
  • 355 Answers
Follow this steps 1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly
Posted on May 18, 2009
  • Rohit  Asthana
    Rohit Asthana May 18, 2009
    re
    load drivers and your pc will communicate with your printer..
It's producing two vetical white strips across the page when printing.
Toner drops from the cartridge onto a dark glass (laser?) below and prevents that part of the image from being transferred. Wipe clean and the problem disappears.
Jul 28, 2010 | Xerox Phaser 6115MFP/N Laser Printer
Xerox Paser 7400 is not recognizing black toner cartirdges after they are installed
Have you shaken it well and be sure you have all the tape removed from the cartridge? Most of the time with that problem the piece of tape that is over the opening of the cartridge does not come off completely.
Feb 09, 2010 | Xerox Phaser 7400/N Printer
Printing problems
Hi!
Could be a couple of things, but it sounds like the tires on the paper roller have worn out.
Like tires on a car, the slightly abbrasive surface of the rubber tires on the paper roller will go smooth over time...causing the rollers to slip on the paper instead of pulling it throuh the printer.
It's a relatively cheap/easy to install part.
You can contact Xerox for the part: www.xerox.com or other websites such as: www.sparepartswarehouse.com.
There may also be a local Xerox service centre where you live (most major cities have at least one) & the tires will be a very common part for them.
...If it's not the tires, it could also be the mechanism that lower the roller onto the paper. If this is damaged (or not calibrated correctly) the printer will have problems feeding the paper through as well.
The only easy suggestion here (if you're not comfortable replacing parts yourself) would be to take it to a registered Xerox service centre for maintenance.
Hope this helps!!
Dec 04, 2009 | Xerox Phaser 6115MFP/N Laser Printer
Mac upgrade means Xerox printer won't print!
There are apparently incompatibilities between some Xerox drivers and the security-improved Snow Leopard. It seems that many pieces of software (and drivers) relied on not-so-clean techniques to cut corners while operating. These techniques are no longer allowed by Snow Leopard (the same problem afflicts XP SP3, Vista and Seven).
This article lists several problems, explanation and (perhaps) fixes:
http://www.ucalgary.ca/it/news/4366
Meanwhile, Apple is working to some workarounds too (there is an update linked in the article which may be of interest to you).
Nov 08, 2009 | Xerox Phaser 6115MFP/D Laser Printer
Our Paser 8560n won't print, sz Fault code
Here is the info from the service manual
Harry
8500/8550/8560 PEST description
37,017.44: Deskew Clutch Disconnect.
The Deskew Clutch is not
drawing the expected power.
Oct 09, 2009 | Xerox Phaser 8560N Laser Printer
Replace Paper Tray Message won't clear
On the right side of the tray, there are 3 rectangular holes. The "plug" goes in the top hole but, if it came out, it probably won't stay in. I've taped a piece of sheet metal in the hold before to get by. You can buy the part for a few bucks from xerox or inktechnologies. There is a lot of pressure on this plug so it takes something pretty strong to hold.
Mar 12, 2009 | Xerox Phaser 6115MFP/N Laser Printer
I want to add an store email addresses on my xerox phaser 6115mfp
You need to use control center , which can be found at Xerox.com .
But here are the steps.
The MFP ControlCentre (MCC) provides an easy-to-use Graphical User Interface (GUI) that simplifies configuring the Phaser 6115MFP and managing fax directory lists from a computer over USB. The MCC stores configuration and setting information in a .dat file that is uploaded from the computer to the Phaser 6115MFP.
NOTE: It is also possible to save the .dat file to a directory on the computer.
To program dialing and enter recipient e-mail addresses using MCC:
  1. Click on the [Start] button, then point to [Programs], select [Xerox Office Printing], then [Phaser 6115MFP], and then click on [Xerox Phaser 6115MFP MCC]. The MCC window will be displayed.
  2. Click on the [Connect to Machine] button. 'Connection Status: Online' will be displayed in the MCC window.
  3. Click on the [Download] button. The current .dat file will be downloaded to the MCC.
  4. Click on the [Menu] button.
  5. Click on the [+] on the left side of the window to configure Speed Dial, One-Touch Dialing, Group Dial, and e-mail addresses.
  6. Enter the required settings, and then click on the [OK] button.
  7. When finished, click on the [Upload] button, and then click on [Yes] to save these settings to the Phaser 6115MFP.
  8. Click on the [Save] button to save the new .dat file to the computer.
  9. When finished, click on the [Disconnect] button.
Oct 02, 2008 | Xerox Office Equipment & Supplies
Blurred prints
It really sounds like you need to replace the imaging unit.
May 15, 2008 | Xerox Phaser 6115MFP/N Laser Printer
Xerox Paser 7700 not printing seemingly large files from CDR13
Have you tried downloading a different driver?
Sounds like that may be the problem
Nov 01, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser™ 6115MFP/N All-In-One Laser Printer Logo
111 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
