Question about Magellan eXplorist GC Handheld Geocaching GPS Navigator
Stuck booting up, ust continues to loop like it's starting up but doesn't.
Bravia 49X8005 continuous boot loop? what do I do?
Corrupted firmware. An update is necessary. Contact the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Oct 08, 2016 | Televison & Video
Sansa Clip Boot Loop
My Sandisk Sansa Clip + is not working, it's stuck on the Sansa logo, the Flower, Refreshing to the Media, Then, it turns back off and starts again, help me Please, Thank you.
Mar 03, 2013 | SanDisk Sansa Clip+
Garmin 1340T boot loop issue. The unit
Unfortunately, there isn't an easy solution for the Nuvi owner as it requires a custom piece of firmware to flash the unit to make it at least boot. This problem is often caused during a failed firmware and/or map update.
It sounds like a file was corrupted. Sometimes it is better to connect the unit up to a PC, delete the old map and then proceed to install the new one. There are so many issues with memory space causing failed downloads and corrupted files.
If the map file is missing, the unit will boot-up OK, it will just say "Map data unavailable" but if the map file or associated map files are corrupted, it can cause the unit to crash. Your PC won't recognize the Nuvi because you have the reach the main screen before the data communication mode routines are accessed.
We've had some success in restoring some of these units by flashing a "fix" firmware in "pre-boot mode" that doesn't try to load the map or map associated files. This should then allow the unit to boot. Once the unit boots, Windows will recognize it and then you can copy a map over to it from the PC. Reboot the unit and then flash it with the standard firmware.
- Jim
Feb 23, 2012 | GPS
E- computer turn on then the screen says it was shut off improperly. say click to restart or wait.....did this it ran through its process and went to screen with no signal. ran it again under boot and...
looks like it's stuck in a startup loop, can you boot from a windows cd into repair console (press R to repair with xp, choose repair my computer with vista or 7) ?
if so, type the command fixboot and after that fixmbr, if it still doen't work, try the chkdsk /F /R
command. if that doesn't work, try booting in hirens boot cd (download v13 and burn it to a cd rom) if still no success, you need to reinstall windows, if that doesn't work, replace the harddisk and reinstall.
Jun 17, 2011 | E-Machines eMachines Desktop PC
My MC9090-G scanner is stuck in boot mode. I've tried a cold boot and warm boot and nothing works.
Actually if it is continuously rebooting, it is usually because someone was holding down the trigger through a cold boot process. That's what puts it into this continuous reboot loop. To get out of it do a cold boot again (pop the battery part of the way out, hold down the power button and trigger simultaneously, and then push the battery back in while the power button and trigger are still down). But as soon as you push in the battery to the point where you hear it click, release the trigger. If you hold it in too long, the unit will start continuously rebooting.
Thanks,
Brad Radaker
Radicomm, Inc. (makers of QuickTalk - push-to-talk for the MC9090)
www.radicomm.com
Nov 21, 2008 | Symbol MC9090-G LORAX MONO 64/ 64MB 53 VT...
Problems during boot
this is windows unable to get to passed the lower bios memory before windows takes over with the normal memory. Check your cmos battery is'nt low, or reset the bios JBAT1 terminal from pins 1-2 to 2-3 then back again as the loop could be corrupt bios or a peice of hardware that cannot be started.
Jan 17, 2007 | Gigabyte GA-8N-SLI Motherboard
Magellan eXplorist GC Handheld Geocaching GPS Navigator Logo
57 people viewed this question
Top Magellan Sport & Outdoor - Others Experts
Bill Eager
Are you a Magellan Sport and Outdoor - Other Expert? Answer questions, earn points and help others
