Question about Vizio 2.1 ch. Sound Bar with Wireless Subwoofer - Home Theater Systems
Woofer is humming
Why is it making this noise
  • 46 Answers
Usually a faulty cable or blown speaker will cause a humming. If it is a constant humming I would surmise a faulty cable. On the other hand, if the humming comes and goes I would guess a faulty speaker.
Posted on Jan 07, 2014
Humming sound cumin from my creative inspire 4.1 woofer
Make sure that you've fully pushed in the jack to the sound card.....maybe you've not connected the jack into the correct socket on your soundcard as there are usually 3 identical sockets...but only 1 is the correct one. Sometimes colour-coded green. Try it in each one in turn. If you have headphones, try plugging them in as you will hear sound in them when you've got the correct socket!
Apr 27, 2012 | Creative Labs Audio Players & Recorders
My acoustic research hd510 has a loud humming noise
check your audio line in connection, either L or R signal line floating may also cause humming noise. Sub woofer usually very sensitive. If your audio input not connected, do you still hear humming noise? in actual you should not hear such noise, unless volume at max then it is possible to hear little.
Apr 03, 2012 | Acoustic Research HD510 System
Woofer maiking a loud noise
be more specific, what type of noise? Humming noise or cracking noise or pop noise? can you still hear noise without signal input line connected?
Mar 05, 2012 | Acoustic Research 308 HO Speaker
Two speakers hum noise
Very doubtful that hum issue is ground potential difference from multiple power outlets as power cord is not grounding type (it is transformer isolated). I do agree that it is good practice to connect all audio equipment to common power strip though, especially with pro sound. Check the audio cords connecting your speakers to the coumputer sound card: 1) Make sure they are connected to the correct jacks and plugged in all the way, 2) wipe the connectors off with a clean paper towel wetted with a smidge of WD-40, 3) replace cords if all else fails. I have also seen solder joints fail on the power supply capacitors (due to vibration) causing hum -- but leave this repair to an electronics technician due to dangerous voltages.
Sep 25, 2010 | Altec Lansing AVS 500 Computer Speakers
Speaker makes a rather loud humming noise.
You can go buy a audioquest SUB-X subwoofer cable with a additional ground wire on it an connect the ground cable to the ground slot of the receiver an the other end to a screw on the sub or into one of the high output terminals on the woofer if it has them an this will take that humming sound right away but the cable is around $90
Mar 28, 2010 | Velodyne HGS-10 Subwoofer
Low sound and buzz from speakers / Hum noise from sub-woofer
Select Start > (right click) My Computer > Manage
In the Management window select > Device Manager
Next to Sound, Video and Game Controllers click the + sign
A yellow triangle will signify a problem so if one is present, right-click that device and select Properties
You can then choose to update the driver
For more details check Dell Xps 420 Manual.
Dell Xps 420 Manual
Apr 14, 2017 | Dell A525 Computer Speakers
HUM noise at PSW3000 if i connect the Yamaha RX-V995
the conections some where are dirty you need to unplug everything clean all connections and the hum will go away
Nov 06, 2009 | KEF Audio PSW 3000 Subwoofer
Humming noise when woofer turned on
check the NPN and PNP transistor output maybe shorted.....
Jul 07, 2009 | PSB Image Sub Sonic 6i Subwoofer
Loud noise from subwoofer on standby or while playing music
Hi There, Please advise us what happens when you turn off the sub woofer is the hum still there....??
From YUBEUT.
Nov 27, 2007 | Teac CD-X8 CD Shelf System
Denon AVR-1601 Receiver
Check capacitors in power supply......also check for over-heated
resistors..all 1 ohm.....replace if cooked...................T.
Nov 21, 2007 | Denon AVR-1601 Receiver
Vizio 2.1 ch. Sound Bar with Wireless Subwoofer - Home Theater Systems Logo
155 people viewed this question
Top Vizio Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
