Question about Vizio 2.1 ch. Sound Bar with Wireless Subwoofer - Home Theater Systems
Subwoofer is hummig what is this noise - Vizio 2.1 ch. Sound Bar with Wireless Subwoofer - Home Theater Systems
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 25 Answers
Hum is a constant low-frequency buzz, usually at about 60 Hz or 120 Hz, which results from voltage differences between true "ground" (what you'd get shoving a copper pipe into the ground) and the electrical "ground" of your receiver's chassis When this voltage differential exists, it's called a "ground loop," and the hum it produces is darned annoying. You'll hear the hum mainly from the subwoofer because it's a low-frequency noise, you will need a ground loop insulator they are about $20 at any electronic store
Posted on Dec 28, 2013
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Hum noise on laptop
May be feed back. Check mic options and mute. Also use a power surge protector.
Sep 25, 2012 | Toshiba Satellite Computers & Internet
I have a 1999 silverado z71 4wd, everything was working fine, until i was fooling around and i was in drive rolling to a stop, then shifed into reverse to backup and hit the gas to hard- but it just rev'd...
If you check again, you are likely missing 2nd and 4th gears, as well as reverse. This is because you have either stripped the spline out of the reaction shell or broke the spline off of it. This failure is very common, and when you put it in reverse as you did, you just helped it fail sooner.
Jan 19, 2011 | 1999 Chevrolet Silverado 1500
Amp makes noise when volume is off
Subwoofers are more susceptible to magnetic and radio frequency interference than your average speaker, or more commonly called RFI.
If you have a RadioShack or other electronics store nearby, purchase a ground loop isolator. This will ground any of the stray electrical pulses around your subwoofer. It is very easy to install and plugs directly into the RCA jack of the subwoofer and should eliminate the problem.
If this does not solve your problem, I suggest bringing your unit in for service if the noise is bothersome.
Aug 18, 2009 | JBL ES150P Subwoofer Speaker
What cause subwoofer to make constant noise(loud)
usely it turn out to be a ground issue make shure there are grounded with the PROPER guage of wire or heaver the required
Jul 15, 2009 | Infinity BASSLINK Car Subwoofer
Subwoofer stopped working
You have a bad connection to the subwoofer.
Mar 07, 2009 | Monitor Audio Radius R360 Subwoofer
JBL PB10 subwoofer, it makes a loud burp noise when it comes on.
In the industry - It is called "Turn-On Thump".
There are some manufacturers that eliminate components like noise filters on enry level lines to save money.
There is no way to lessen this noise without ripping the amplifier apart and having a technical knowledge of the way amplifiers work. It would involve hard-wiring a slow charge capacitor in the turn on line so it gradually builds power instead of getting it all at once.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 10, 2009 | JBL PB10 Subwoofer
SONY SA-WM500 SUBWOOFER
firt you clean the subwoofer with cleaner after that, check the subwoofer srrounding, no electrical wire ,mobile phone & electrical operated items is near ur subwoofer.
1. Do not use maximum volume of subwoofer.
2. Use only 65-85% volume of your sub woofer.
Sep 25, 2008 | Sony SA-WM500 Subwoofer
Vizio 2.1 ch. Sound Bar with Wireless Subwoofer - Home Theater Systems Logo
231 people viewed this question
Top Vizio Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
