Question about GARDENA Hardware & Accessories
1265 manual - GARDENA Hardware & Accessories
I am locked out of garage. Liftmaster 1265 will not open.
Sounds like what you need acces too is inside the garage. If you don't have a pedestrian access door to your garage, or a window, or these are both locked, you are going to have to break something. Sorry to tell you that. Just pick the thing to break which is easiest to repair. Once inside, there is a mechanical release (usually a pull rope hanging from the opener main unit) that allows you to open the door manually. Then you can use the garage until you can address the problem. Good luck.
Oct 23, 2012 | liftmaster Chamberlain Garage Door Opener...
I need to find a manual online for a White 1265 sewing maching.
go to http://www.singerco.com/accessories/manuals.html, search by typing "1265" into the search field and you should be able to download it as a PDF.
Apr 27, 2011 | White Sewing Sewing Machines
I need a manual for an intertherm oil gun furnace model mac 1265
I'm looking for the same... If I find one I'll post back here
Jan 04, 2011 | Heating & Cooling
How do you install a side exhaust vent for this unit?
Hi, You have to order a side exhaust kit from the manufacturer. Part number: WTZ 1265. Phone number from the owners manual is 1-800-944-2904. If you don't have the manual, I found here: https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=thjozmkcdcso0pdmdb---oAK&UMOBID=thjozohcdcso0pdmdb---oAK
Pages referenced were 18 and 32, best of luck.
Feb 02, 2010 | Bosch Nexxt 500 Plus Dryer
Chamberlain 1265 garage door opener, tried to
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hardware & Accessories Logo
24 people viewed this question
Top GARDENA Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Bill Boyd
Are you a GARDENA Hardware and Accessory Expert? Answer questions, earn points and help others
