Question about Car Audio & Video
Pioneer gm-2000 wiring diagram - Car Audio & Video
happy_colors
SOURCE: Pioneer GM-232 Amp
amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgthese are from the actual owners manuel-i used to have this amp also. hope these help
Posted on Dec 29, 2008
  • 146 Answers
SOURCE: amplifier wiring diagram
These amplifiers are universal. You have the speaker positive negatives, power "Red", Ground "black", and remote off/on "blue". Thanks
Posted on Jun 08, 2009
SPL Freak
  • 63 Answers
SOURCE: need a wiring diagram for a pioneer GM-840/UC
http://caraudio.manualsonline.com/ex/thread/view/idThread/2909343
Posted on Mar 06, 2010
emissionwiz
  • 80531 Answers
SOURCE: what guage wire do i need for a pioneer gm-x542
14 or 16 gauge 16 is easier to work with
Posted on Apr 27, 2010
fkuk
  • 311 Answers
SOURCE: hi, just trying to wire up my pioneer gm-620 car
i need to know is the blue wire comming from the amplfier or comming from the radio?
if its comming from the amplfier then
you need to connect this to the igintion wire (yellow) or if the radio has it connect it to the radio (it shoudl become 12V when radio turns on)
if its comming from the radio then
you need to connect it to the remote jack in the amplfier
the wire become 12V when the radio turns on
and the amplfier only turn on when the remote connection on the amplifier becomes 12V
Posted on May 14, 2010
HOW do I install my Pioneer 4 channel power amplifier GM X 84 along with my pioneer DEH-17 cs player .? A wiring diagram is needed
If you are using two amplifiers used one the amplifier to power a sub woofer on you though frequency the other amplifier willpower the rest of speakers make sure your power wires are separate and the both run at 15 to 20 A
Aug 09, 2014 | Car Audio & Video
Diagram for pioneer gm-34a
Here is the manual for the GM-3400. 34 "A" does not exist. Here you are:
http://retro-caraudio.servehttp.com/guide2/images/Brukermanualer/Bilstereo/Pioneer/Amps/GM3400.pdf
Jul 13, 2014 | Pioneer Car Audio & Video
ON A PIONEER CAR UNIT MODEL AVHP49000DVD , I BOUGHT IT USED , THEN HAD TO BUY A POWER PLUG FROM PIONEER WITH A WIRING DIAGRAM , PUT IT IN MY 2006 GMC TRUCK WITH A FACTORY WIRING ADAPTER IT WILL NOT COME...
You will need to connect the pioneer unit to a switched ignition wire from the ignition switch. The 2006 GM factory radio only has a constant B+ (orange wire) and ground (black wire). The factory radio turns on when the Body Control Module (BCM) sends the radio a turn-on signal (on a data communication line) when the key is turned on. Your pioneer unit won't talk to the truck's BCM, and will need you to wire a switched B+ feed to it that turns on in the ignition accessory and run positions.
Aug 23, 2013 | Pioneer Avh-p4900dvd, Avhp4900dvd,...
Pioneer GM-232 Amp
Dec 29, 2008 | Pioneer GM-232 Car Audio Amplifier
I need a wiring diagram for a Pioneer GM-A200 Amplifier
For a Pioneer GM-A200, pls use below wiring scheme:
  • Green & Green/Black - Left Speaker;
  • Gray & Gray/Black - Right Speaker;
  • Yellow - Illumination B+12;
  • Red - ACC B+12;
  • Orange - Always ON B+12;
  • Black - Ground/Chassis.
For the 8P INPUT DIN connector:
  • 1 - SWD +B;
  • 2 - Left Input
  • 3 - Audio Ground
  • 4 - Mute
  • 5 - Right Input
  • 6 - UN SWD +B
  • 7 - Illumination B+12
  • 8 - NC
  • Body - Ground
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 23, 2008 | Car Audio & Video
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
Instalation of a gm-x622
Trim God Hey Kell77. Go to this site if you have not already tried this. I found your amp but no manual. http://www.pioneerelectronics.com/pna/v3/pg/product/details/0,,2076_310069937_36965,00.html If that does not help, Google "Pioneer" and check out each site till you get what you need.I found the manual on this site,but it costs 9 bucks. Maybe you can get it for free if you search around a bit.http://www.tradebit.com/filedetail.php/824757. If you can't find a manual for your exact amp, download a manual for the same model type that is less or more powerful than yours. The wiring diagram for all the GM-X models might be the same. Just use your judgement and caution when wiring it up.
Oct 02, 2007 | Pioneer GM-X722 Car Audio Amplifier
Car Audio & Video Logo
406 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
