Question about Samsung DVD-VR375 DVD Recorder/VCR
Cd-r disc won't load; gives
I'm trying to convert an audio tape (from external tape deck) to cd. Cd-r disc won't load; gives ''error'' message and rejects disc. The unit does play audio cds without any problem.
  • john_mahony May 27, 2009
    I'm trying to convert an audio tape (from external tape deck) to cd. Cd-r disc won't load; gives ''error'' message and rejects disc. The unit does play audio cds without any problem. I have had the same result with CD-R 700MB/80 min discs manufactured by Sony, Maxell and TDK.
    The unit is able to recognize and record on DVD-R discs from Sony. Is a different lens used for CD vs. DVD?
  • 464 Answers
I checked the website for your problem. though it can play the audio cds it will able to write only dvd's only. i found this message from the samsung website
(http://reviews.cnet.com/dvd-vcr-combos/samsung-dvd-vr375-dvd/4507-6505_7-33004024.html?tag=mncol;psum)... so nothing is wrong with the recorder. it will be able to write only dvd's(DVD+R, DVD-R, DVD+RW, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL ) but not the cds.
but it will be able to play the following versions(CD, DVD, CD-R, CD-RW, DVD+R, DVD-R, DVD+RW, DVD-RW, DVD-RAM, DVD+R DL, DVD-R DL ).
hope your problem is tackled.thanks for using fixya!. please dont forget to rate my solution.
Posted on May 28, 2009
    Novelist:
  • 151 Answers
I will explain the problem.in your player there are two laser lens.its dual lens assembly player.the 1 laser lens for audio cds .and 1 laser lens is used while converting the disc.but in your player the laser lens which reads the audio disc is proper ,but thw 1 which comes in use for making the cd is got faulty.as the laser lens detects the cd in the drive.if the lens is faulty it will not detect,so you will get the message as follows "error" or "no disc".so the laser lens in your player needs replacement.to solve the issue.a local dvd,vcd,electronics repair store.can get the lens replaced for you in the player.then it will work properly.many of my clients are having the same probklem and after replacing the lens player starts working as normal.
this will help you.
thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 27, 2009
    President:
  • Samsung Master
  • 2,923 Answers
This just a possibility why it won't work:
1. Your drive doesn't like that particular brand of disc media.. Some are picky!
To isolate it:
1. Try different brand of disc.
2. Try to load the 'problem' disc into different CD-R drive to see if that would work.
3. If you've got an old drive, you may need a new one which has a new laser which reads and burns discs better.
Hope this help and have a great day!.
I keep getting check cd & check tape message.
CD Player fix for "Check Disc" won't load - SINGLE - Chevy ...
coloradofans.com > ... > Tech Talk > Technical Questions / Tips / How To
It would take it in, then spit it out saying "Check CD", and the whole time the motors would be either ... This plate had pieces of felt tape on my particular deck.
Check CD error message - ecoustics.com
www.ecoustics.com > ... > Archive through June 23, 2007 Forum
Jul 6, 2004 - i am getting a continous "check cd" error message on my car cd player (chevrolet impala). Everytime this message is displayed I hear a
Oct 24, 2015 | 2000 Chevrolet Impala
How can i use RCD W1 to convert audiocassette to audio CD ?
What you need is a tape deck with 2 rca line outs L&R. Hook them up to the analog ins on the player. rec on deck b. Dont forget to get the right cdr's , i guess you need "music" or "Audio" crd-r's
Aug 30, 2011 | Sony RCD-W1 2-Disc CD Recorder
When i install cd it says error 6 on my clarion dxz465mp
Clarion Audio error codes:
Error Codes:
Error 1 Battery inside CD Changer needs to be replaced.
Error 2 CD error message. Mechanism has as eject problem or takes a long time to select CD.
Error 3 CD error message. The pick-up is out of focus during play mode due to scratches on the disc or contamination.
Error 4 Connection problem. Reconnect the data cable.
Error 5 CD error message. Could not read correct data due to CD ROM.
Error 6 CD error message. Could not read data from disc because it is upside-down.
Error 8 Tape Drive system defective. Eating tape or something wrong with the drive system.
Error 9 Weak RF. Try alternate frequency
Even though it says error 6 is an upside down cd, it just means the disc cant be read. usualy means the laser is dirty, out of adjustment, or not working.
Aug 19, 2009 | Clarion DXZ465MP CD Player
Cd won t eject from 2006 Ford Focus mp3 player Get eject error message How can I safely remove CD''
HI, either the deck assembly is jammed or, the load motor has failed. In this case, you will need to disassemble the entire set in order to retrieve this CD.
The actual loading deck(the part where the CD is located), is surrounded by a metal housing. the gear assembly is probably locked, due to this jam or failed load motor. This will also require a set of precision tools as well. if you find this a bit overwhelming, i suggest taking this unit to a local automotive audio shop. they can dissemble it and, retrieve the CD for a small price.
Jun 21, 2009 | Kenwood KDC-MP638U Car CD/ MP3 Player
Have alpine chm s620 ,error message say no disc magazine is loade
have you tried a different magazine.  Could this one be warped?
Apr 03, 2009 | Alpine CHM-S620 6-Disc CD Changer
Disc won't initialize or record, keeps saying no disc or opc erro
I suggest you try cleaning the lens...
If the wrong disc was inserted, say a music disc, there would surely be a message to that effect. If no such message is displayed I would guess the unit is faulty.
Apr 13, 2017 | Philips CDR778 2-Disc CD Recorder
Jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Nov 07, 2008 | JVC KD-LX111 CD Player
Clarion DB175 cd player
The Clarion manual lists 3 error messages.
Error 2-A disk is caught inside the CD deck and is not ejected.
Error 3-A disk cannot be played due to scratches, etc.
Error 6-A disc is loaded upside-down and cannot be played.
Good Luck.
Mar 26, 2008 | Clarion DB175MP CD Player
No Audio 10 Error
What have you got hooked up? Another CD, tape outs from an amp or a record deck? No audio is a strange message to get, like you say you're using an audio cdr and that's usually what it means. What about if you press record with *no* source connected? Unit should record 20 seconds of silence then cut off.
Jan 20, 2008 | Philips CDR765 2-Disc CD Recorder
Lost the manual, can't get hooked up
You need to use an audio CDr, data or computer CDr's will not work in this machine. I don't know this specific machine, but usually you select the input, then 'rec type' eg manual,1 track or 1 disc,then press record to get into record pause,start your source,then press play on the unit to start recording. To finalize, you press finalize then either the play or rec button to start the finalize process.
May 28, 2007 | TDK DA-3826 2-Disc CD Recorder
Samsung DVD-VR375 DVD Recorder/VCR Logo
85 people viewed this question
Henry  Thomas
Henry Thomas
