Question about Kinyo Audio Players & Recorders
Got a kinyo BT-150 speaker. it says device is connected but no sound is coming from speaker
  • 23 Answers
SOURCE: kinyo speakers will not work on my computer
First thing I would try is to figure out if this is a speaker problem or a system driver problem or hardware issue. First, try using headphones from an ipod and plug them into your computer and listen. Check for the input and not to mistake the miocrophone input. They should be clearly marked. If it works then its your speakers. If it does not work, you should try reloading your drivers. You can download the drivers from the company website or you may have the drivers on the system restore CD that came with the computer. Another thing to try is to reinstall the hardware. Sometimes, their is a confict when you install devices like webcams. You can verify that you do not have a problem by contacting the webcam company. Try contacting the manufacturer of the computer if it is within the last few years. Worst case, bring it in for a diagnostic to a local PC repair. Should be an inexpensive fix, less than 50.00 Hope I could help point you in the right direction Mike
Posted on Sep 09, 2007
  • 17 Answers
SOURCE: no sound!
If they are new speakers make sure that there are no drivers that need installing some motherboards need configuring depending what kind of motherboard if not return them to shop for new speakers
Posted on Jan 26, 2008
myjosh007
  • 530 Answers
SOURCE: I HAVE KINYO SPEAKERS AND NO SOUND IS COMING OUT
hi im josh in cebu phils. friend if it enable before and now not and it quits. most of this problem is the audio card or audio socket. these maybe a software or hardware problem. all you have to do first is to check the control buttons be suret was not chek to mute or adjust ir to higher volume if it s low. you can see the button near the time bar right side of the screen or re install your audio driver from the cd. and try to hear it again, if not try to cher\ck your connections like the small wire cable at the back of the speaker check if it wasnt cut. or check the audio socket colored green at the back of the pc. if it still doesnt work replace your audio card if you are using audio card if it is built on pc main board try to buy a audio card and install it.good luck hope i helped you.
Posted on Feb 20, 2009
sardanadixit
  • 813 Answers
SOURCE: sounds are not coming from the speakers. speakers
Try this:
Click Start, select Run, type "services.msc" without the quotes and press Ok. Services window will open up. In that window, select the Windows Audio Service and the status and startup type of the same. In case the startup type is disabled, double click on it and select the startup type as Automatic. After that right click on this service and click Start. In case the Start is greyed out, click on Restart. Now check for the sound.
Posted on Jul 07, 2009
lock123
  • 6831 Answers
SOURCE: no audio
Hello
Have you remembered to install the sound drivers ?
If you have just reinstalled windows you have to install all the drivers for the needed devices as well in order for everything to work propperly. Hope this can solve your problem.
Best regards
Andrea
Posted on Nov 04, 2009
Kinyo bluetooth speackers wont work
The drivers may not be established for the device mentioned. Or you may not have a Bluetooth communication device for the computer. The speakers have a BT receiver, and require a BT transmitter plugged into your source device (Computer, Radio, etc.).
Jan 12, 2014 | Audio Players & Recorders
What can i do if my kinyo speakers dont work since my computer crash and the coumputer cant fine enoght data to instal that hardwer
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 25, 2010 | Kinyo PS-107 Computer Speakers
I want driver supporting it
this is a plug and play device, it does not need drivers
if they are not working make sure your computer sound card has its driver loaded and the speakers are connected to the green audio jack in your computer
Aug 13, 2010 | Kinyo UC270B 2 Speakers
No audio
Hello
Best regards
Andrea
Nov 04, 2009 | Kinyo PS-107 Computer Speakers
NB-100 speakers aren't registering
kinyo products are designed to automatically upload drivers to your computer from an onboard flash drive, if your computer says unrecognized device you should try and exchange them for another pair.
Aug 14, 2009 | Kinyo Audio Players & Recorders
I hook the system up to my tv and no sound comes out the speakers
If you are using a single black co-ax cable, or three color composit cables, then those are video only.
You will need a seperate cable for sound to the TV, or connect to the computer speakers like normal.
Apr 29, 2009 | Kinyo Game Zone 4.1 Speaker System...
No sound!
Jan 26, 2008 | Kinyo SA-626 Computer Speakers
Kinyo speakers will not work on my computer
Sep 08, 2007 | Kinyo PS-107 Computer Speakers
Top Kinyo Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Jerry Umali
Jerry Naidoo
Are you a Kinyo Audio Player and Recorder Expert? Answer questions, earn points and help others
