Question about Acer Computers & Internet
Computer went black I turned it off, tried to turn it back on
I have tried taking out the battery and us AC only still the light will turn on for 1 sec and go back off.I can hear the computer try to turn on. Is this the battery or ???? I have had this computer for 16 to 18 months
  • 39 Answers
That's typical of burned motherboards.  it may have been a power surge or oversupply of voltage.  some motherboards have an overvoltage protection.  see if the AC adapter shorted and is somehow outputting a higher voltage than it should.  typical laptop voltage is 19v.  if you have an aspire one, it will be less, probably 12 or 9.5.  try another compatible ac adapter to see if that fixes the problem.
Posted on May 18, 2009
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Compute turns on, lights light up, and fans move, but there are no beeps or bios showing up.
Computer turns on but no display. This issue is commonly caused by electrical static on the motherboard. Try doing a power drain.
If this computer is a laptop:
1. Turn the computer off by pressing the power button for a bout 5seconds.
2. Take the battery out of the computer.
3. Unplugged the ac adapter.
4. Press and hold the power button for about 30 seconds. (without any power source)
5. Put the battery back in and plug the ac adapter back into the computer.
6. Turn the computer back on.
If this computer is a desktop:
2. Unplug the power cable from the computer.
3. Press and hold the power button for about 30 seconds. (without any power source)
4. Plug the power cable back into the computer.
5. Turn the computer back on.
Thank you for choosing FixYa! have a good one!
Jun 02, 2011 | Computers & Internet
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
I have a Dell Inspiron 1545 Laptop. Just went to turn it on and you can hear it start but the screen is black. I tried the power cord/battery thing and it didn't work. Also I was reading about a magnet...
Hi cspeer1201,
Black screen is often caused by a defective screen. The easiest way to determine if you have a hardware or software problem is by performing a power drain. Please follow the steps below for additional instructions.
Power Drain:
1. Turn off the computer.
2. Unplug the AC adapter from the power outlet and take out the battery from the system.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Turn on the system and try observing it.
--> If power drain did not work, you need to consult a repairman to have the LCD connector be replaced.
Hope it helps.
Thank you for using FixYa.
Apr 28, 2011 | Dell Inspiron 1545 Notebook
I am unable to get the netbook to boot up. It turns on, I hear the Hard drive humming, but it only goes to a black screen with a cursor that won't work either. All I did is leave it on at night (which I...
Try draining the flea power first
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
check if it will boot to windows, if not, there is a problem with your windows OS, try using startup repair. Hope this helps
Dec 11, 2009 | Acer Aspire One AOA150-1570 Notebook PC
My montitor on my laptop went off last night, after messing with the mouse for a minute, i shut it off, now it will not come back on. when i hit the power, the light on the battery button in the front...
1. Turn OFF the Computer, remove the Battery and disconnect the AC Adapter also.
2. Press and hold the Power Switch for 5 seconds.
3. Insert the Battery in the Computer an try turning ON the Computer.
4. If the issue persists, remove the Battery, press and hold the Power Switch for 5 seconds.
5. Connect the AC Adapter and try turning ON the Computer(without Battery).
NOTE: If the Computer turns on without the Battery, connect and charge the Battery for 24 hours.
6. Disconnect all external devices that are connected to the Computer.
7. Attempt to turn ON the Computer.
8. Remove any additional Random Access Memory (RAM) that was installed in the Computer.
9. Attempt to turn ON the Computer.
This should resolve the issue.
If the issue still persists, then service may requires to resolve the issue.
Nov 22, 2009 | Gateway M-6843 Notebook
Pc will not come on. Runs Hot. Will not click off.
have you tried to remove the battery and disconnect the ac-power?
then reinsert the ac-power (without battery)
and try to boot.
if that doesnt work:
remove battery and ac.
turn computer upside down. under one of the lids there will be 1 or 2 memory modules (ram). take them out
insert ac
try to start the computer (yes, without the ram modules)
leave the computer on (with black screen) a couple of seconds.
remove the ac
insert the ram again.
insert ac
try to boot again.
May 29, 2009 | Acer Aspire One PC Notebook
Wont power up
the vr\ery first thing what u have to do is that disconnect the ac adaptor and take the battery out of the computer and then press and hold down the power button without the battery and the adaptor for one minute and then connect the ac adaptor and put the battery back in and then try and turn it on and what u can do is that try and turn on the computer only with the battery and then take the battery out and try and turn it on only with the adaptor,and then what u can try is that try with the different adaptor having same configuration,and try and connect the ac adaptor into the different wall outlet....good luck
Jan 28, 2009 | Dell Inspiron 6000 Notebook
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
53 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
