Question about Akai PT5492S 54" Rear Projection Television
Red shadow I have an AKAI big screen TV and it is messing up. The problem is that the TV has a wavy, red shadow mirroring all people, fonts, and everything else. It almost has a rainbow reflection of red of everything on the screen. I tried to find an option that would refresh the t.v. screen but with no luck. Please help me go in the right direction on how I should approach this situation. akai 54" 1080i Thank you, Stephen Basche
  • 1 more comment
  • stevaroo85 Oct 17, 2007
    IC's?? I am unfamiliar with this term. Can you do this manually or do you have to hire a technician for it? Can you buy it at Wal-Mart if it can be done manually? Please advise.
    Thank you very much,
    Stephen Basche
  • Anonymous Nov 05, 2007
    yep red lines too
  • lonnie90014 Nov 12, 2007
    trouble with blue convergence, blue and yellow shadow, auto convergence says, check factory data
    Genius:
  • 1,694 Answers
Replacement part # STK392-040 X 2 ( replace both for reliability )
I use Panasonic brand to eliminate re-calls. Less than first quality will fail.Always willing to help.....T.
Posted on Oct 22, 2007
    Problem Solver:
  • 11 Answers
It sounds like you are having convergence problems if that is the case the ic's will have to be replaced
Posted on Oct 17, 2007
  • tim panik Oct 18, 2007
    you will have to hire a technician these parts will need to be solidered in an ic stands for integrated circuit it should cost about $300
We need to figure out how to get it off of the 3d setting we just recieved this tv from a friend of ours and we are trying to figure out how to view it without the 3d our tv is a mitsubishi big screen...
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D, wavy, or has a shadow or shadows
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 29, 2011 | Mitsubishi WS-65907 65" Rear Projection...
Hi, I'm having the same type of problem with my tv. It has the 3d look to the screen but it also has a large wavy red line through the top of the screen. Would this also be the result of the convergence...
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 28, 2011 | Hitachi 51F500 51" Rear Projection...
The red in the picture is shadowing the rest of the picture giving it a 3d effect
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 23, 2011 | Sony KP-53HS30 53" Rear Projection...
Projection screen bowed?
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 23, 2009 | Akai PT4298HD Rear Projection Television
I have an akai rear projection big screen tv that has blue shadows on everything. When the auto focus turns on, about half way through the process, everything clears up. When the auto focus completes, the...
Replace the Blue convergence IC, But you should consider replacing both of them, because if one has failed then the other is likely to sooner or later. They are large Black IC's mounted on a Metel Heatsink. I believe on this model the board is in the middle of the unit. Before you replace check the solder connection on the Ic's first you might just have a few cold solder joints, if not then replace both IC's
Nov 09, 2009 | Akai PTH5498 54" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Red shadow
*Screen Looks 3-D
*Colors wont align
Mar 22, 2009 | Mitsubishi WS48511 48" Rear Projection...
Convergence is all messed up
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 27, 2008 | Akai PT5492S 54" Rear Projection...
I have a red and blue shadow in my picture
i think you need a new convergence board they rin from about 88.00 to about 140.00
Sep 08, 2008 | Akai PT5598HD 55" Rear Projection...
Akai PT5492S 54" Rear Projection Television Logo
125 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
