Paper jammed in staples titanium cutter, need to know if lid comes off
4 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: Fellowes PS60 CC shredder jamming
You have guides or cutter assembly out of alignment. Take it apart and double check before reassembling.
Posted on Jun 11, 2009
SOURCE: How do I open the box with the cutters?
There are two additional screws under the labels. You can feel the holes under the labels with your fingertips. Cut a hole in the labels to access the screws.
Posted on Jan 13, 2010
walesarumi
  • 6993 Answers
SOURCE: spl-s2420 is my Staples shredder
1. Press the "Reverse" switch on your shredder with one hand while gently pulling the jammed paper back toward you. This should free any jammed paper from your shredder. If it does not, go to the next step.
2. Turn your shredder off and unplug it from the wall outlet. Allow your shredder to cool down for at least one hour before touching the shredder head and gears.
3. Remove the shredder head from the wastebasket and pull out any clumps of paper in the shredder.
4. Use a letter opener or a pair of tweezers to remove small pieces of paper that you see in the shredder, and then use a can of compressed air to force out stubborn paper particles stuck in the gears.
5. Place the shredder head back on the wastebasket or canister and plug it back in, and then coat a full sheet of paper and the gears with shredder oil. Allow the oil to stand 15 minutes and press the "Reverse" button to test your shredder; this should remove any final debris from your machine.
If this doesn't help, please let me know for further directions.
Regards.
Posted on Jun 20, 2011
It will not staple electronically or manually. It leaves the impression on the paper but no staple comes out. What do we do?
Pull it apart I think that a staple is jammed in the area where the staples come out when activated.
Mar 28, 2017 | The Office Equipment & Supplies
Xerox docucolor 240-250 not stapling/folding, error codes 012-243, 012-229, 012-225
Koday Hero 7.1 carriage jam. Stuck to the left side. No paper jam can be found but can't get the carriage to move.
Nov 15, 2013 | Office Equipment & Supplies
Paper does not feed grinding sound
HI, kate;
go to buy a robber rejuvenator from staple store, clean up paper feed roller, paper pickup roller that will resolve your problem.
Oct 31, 2013 | TransAct ITHACA - 8040 - DIRECT THERMAL...
Shredder blades not turning
A staple or paper clip has jammed the cutter blades.
If there is a reverse switch then reverse to free the cutter blades and remove these objects.
Mar 23, 2013 | Fellowes Microshred MS-450Cs
Paper pulls to right side and then jams it all started when paper jam i pulled it out and ever since then when loading paper it pulls to the right and then jams
Try running a good sized thickness paper thru it to clear out the cutters.
Sometimes when they jam some residual paper is left in the space between the cutter wheels and causes the paper to feed askew...
I use the cover from old phone books.
Sep 29, 2011 | Office Equipment & Supplies
Paper is stuck
You should be able to get the paper out by engaging the reverse switch - this should wind the paper back out of the top. If this does not work the machine is truly jammed and if you cannot get the paper out bit by bit, you will have to strip the machine and remove it that way. Make sure the machine is unplugged as some machines have very sharp cutters and can cause an injury to your hands.
Feb 02, 2011 | Staples Office Equipment & Supplies
STAPLES TITANIUM CUTTER (SPL-TMC16A) CONTINUES TO RUN WITHOUT STOPPING AFTER PAPER HAS BEEN SHRED. THE FORWARD LIGHT FLASHES.
can't solve the problem, but wonder if I could get an owners manual for this same model (SPL-TMC16A)
Dec 16, 2010 | Office Equipment & Supplies
Jun 09, 2009 | Office Equipment & Supplies
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
DOCUMENT FEEDER IS JAMMING
Try and clean the rubber rollers with Isopropyl alcohol. Do not use any solvents.
S. Mohan, Chennai, India
Dec 30, 2008 | HP Scanjet 5590 Flatbed Scanner
42 people viewed this question
jasbo
jasbo
