Question about Belling Freezers
Belling bcm 12 chest freezer
For what is orange switch on the front side.when put for1light orange.
  • 7 Answers
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Posted on Jan 17, 2008
SOURCE: the front surface of the chest freezer is
Hi, can you put your hands on front of freezer, and check from 1 to 5 without getting burn? how long can you keep your hands on front of freezer? check from 1 to 20 and let me know, normally there's a condensate line, or part of condenser lines that passes through freezer body , purpose of those condensate line is to prevent your door gasket from freezing , especially during winter. It's normal for front of freezer to be warmed, on hot days it will be a little hotter, you said "very hot" makes me wonder how hot it is, put your hands on front of freezer, use number method and let me know, but it's normal. good luck.
Posted on Aug 19, 2009
Testimonial: "Thanks for your useful advice."
  • 415 Answers
SOURCE: the front surface of the chest freezer is pretty hot.
the condenser lines are between the walls of the frzr and if it has a fan to cool the compressor down and it is stalled is the reason the walls are so hot and no it will not cool down over time if new is a flaw in making of this unit take it back or if older only the side should be getting warm not hot then if older be cautious of this no repair can be done on these type of unit they are between foam filled walls....
  • 1796 Answers
SOURCE: belling chest freezer, should the
Hi!!
No, the fast freeze button should only be activated when you load a warm or lots of items at once. It should disengage by itself after a preprogrammed amount of time. If Ice cream is too hard, check your temp. settings.
Good Day!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Nov 02, 2010
BIKER T
  • 909 Answers
SOURCE: Kenmore Chest Freezer
Believe it or not, but it is normal. Especially when just turned on. As the internal temp. gets colder so will the temp. on the side get cooler.
Posted on Sep 24, 2013
Hi I have a Belling BCF10 chest freezer. The power light is not lighting but the freezer is still freezing, what is wrong? Also when should one use the fast freeze switch? Thanks in advance
If the freezer is working properly then the circuit that feeds the power to the power light is not working or the light itself is burned out. Either one or the other.
Sep 17, 2016 | Belling Freezers
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
I have a belling chest freezer BCF 20 ... It has an orange fast freeze switch is this switch left on all the time????
No. That is like running it on "high power" full time and could cause it to wear out and stop working much sooner than it's natural life expectancy. It also uses up more than twice the electricity on your electric bill, than it needs to work normally. That setting could also be used in something like a store, where people open it up every few minutes, to keep it cold when it's opened so often.
That switch should only be used for emergencies, like after a power outage, or to quickly freeze foods that were fully thawed and need to be frozen quickly.
Oct 14, 2013 | Belling Freezers
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
The standby light is still on
Are you sure it is a standby light? Usually the orange light is showing you it is in fast freeze. Try switching the orange button off and monitor the temperature. The freezer should cycle on and off, not run continuously.
Apr 15, 2012 | Whirlpool 10 cu. ft. / 283 liter Chest...
We got a philips whirlpool chest freezer my husband pressed orange button as he was told it was turbo boost freezers only cold at bottom and red light is on
Orange switch only by passes the thermostat. It sounds like your freezer is either out of gas or the cooling fan (if there is one) is not working.
Dec 08, 2009 | Whirlpool Freezers
GE 5CF CHEST FREEZER
I got delivery today for the same freezer and had the same question.
I just called GE's customer service number (800-626-2005) and the agent told me that GE uses this button panel (which has the green on/off light switch, the two white switches, and the round control dial) for all or most of its freezers. But the buttons do not do anything on the 5 cubic foot chest freezer. They are not connected to anything and are non-active buttons. On other freezer models above this one, the two switches serve a purpose, but not the 5CF model. This is a simple, inexpensive freezer and it doesn't have bells and whistles--but it does have the same control panel as the multi-feature freezers. Hope that helps.
Sep 05, 2009 | GE 5 cu. ft. / 142 liter Chest Freezer...
An orange light is on next to the green light on my chest freezer
Normally orange signifys that the machine has been switched into fast freeze , check your controls
Sep 04, 2009 | Hotpoint 6.67 cu. ft. / 189 liter Chest...
The front surface of the chest freezer is
Aug 19, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Jan 16, 2008 | Freezers
Freezers Logo
57 people viewed this question
Top Belling Freezers Experts
AJMAL KHAN
James Coghill
Tom Chichester
Are you a Belling Freezer Expert? Answer questions, earn points and help others
