Question about Siemens HM19550EU Gas Kitchen Range
Manual kitchen Having just moved house I find myself unable to to use this cooker as the fascia is damaged.
I have a stoves farmstyle 1100 df cream range cooker. I am having problems with the timer and have bought a new one but I need to know how to remove the top to fit it. The cooker serial number is 050564146
Hi.
To replace the timer control you need to remove the front fascia panel and the hotplate at top.
Before starting disconnect power and move the range forward.
To remove front panel you need to undo the 4 screws at the sides and to remove the knobs, then remove front panel.
To remove the hot plate you need to remove 4 screws at the back. There are also 4 screws at each side of the hot plate. You may need to remove the side panels to reach those screws. There is also an additional screw located behind the control.
Here a service manual for the range Farmstyle 1100E, which is similar to 1100DF. The disassembling instructions for top and front are at pages 62 to 64 of PDF (sections 4 to 6). Control board and touch pad are at page 67-68 (sections C and D of disassembling).
Service manual: Stoves Farmstyle 1100 1st.pub
Regards.
Ginko
Oct 07, 2011 | Stoves 1000DFDLm Gas Kitchen Range
Gas cooker
Probably. Speak with your propane supplier about what will need to be done with your stove.
May 03, 2010 | Belling DB2 Dual Fuel (Electric and Gas)...
Lost cooker manual during a house move
Try downloading a manual from
http://www.usersmanualguide.com/parkinson_cowan/cooking/page3
However, you need the product number code to get the exact manual for your cooker.
Good luck,
bornleader
Sep 24, 2009 | Parkinson Cowan Kitchen Ranges
Instruction/Owners manual for a Leisure Rangemaster 55 Auto
I have the just moved to a house with this same oven. I can't find the exact manual online, but the timer/clock seem to work the same as this one..
http://www.leisurecp.co.uk/upl/15858-GR6CV.pdf
Oct 26, 2008 | Kitchen Ranges
Range master toledo 90
I would follow these requirements if I were you:
The cooker must be connected to the correct electrical supply as stated on the voltage label on the cooker (This is obvious so far!). It should be connected through a suitable cooker control unit incorporating a double pole switch having a contact separation of at least 3mm in all poles (This means one of those big red switches with "COOKER" written on them). The cooker must NOT be connected to an ordinary domestic power point. The cable size used should be between 6mm squared and 10mm squared twin and earth. Where the installation is protected by a 30 milliamp sensitivity residual current device (RCD Breaker), the combined use of your cooker and other domestic appliances may occasionally cause nuisance tripping. In these instances, the cooker circuit may need to be protected by fitting a 100 milliamp device. This work should be carried out by a qualified electrician.
Oct 28, 2007 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Siemens HM19550EU Gas Kitchen Range Logo
77 people viewed this question
Top Siemens Kitchen Ranges Experts
Timllfixit
Bill Boyd
rpar
Are you a Siemens Kitchen Range Expert? Answer questions, earn points and help others
