Question about Avermedia Technology AVer DVD EZMaker 7 C039 Signal Converter - Functions: Signal
Problems installing avermedia dvd ezmaker 7
Directions say to install DirectX 9.0c or above and that it is on the CD - I do not see it on the cd. When I install driver, looks like it is installing then installation box disappears
It has DINPUT.dll error
Dinput.dll errors usually appear when a game or other software program is started. and are caused in one way or another by an issue with Microsoft DirectX.
The dinput.dll file is one of many files contained in the DirectX software collection. Since DirectX is utilized by most Windows based games and advanced graphics programs, dinput.dll errors usually show up only when using these programs.
Solutions:
1. For Dinput.dll not found. Reinstalling Direct X should fix this.
2. Install the latest version of Microsoft DirectX. Chances are, upgrading to the latest version of DirectX will fix the dinput.dll not found error.
Note: Microsoft often releases updates to DirectX without updating the version number or letter so be sure to install the latest release even if your version is technically the same.
Note: The latest version of DirectX should be installed no matter if you're running Windows 7, Windows Vista, or Windows XP. The installation may include DirectX 11, DirectX 10, and DirectX 9 files, but they run side-by-side without problem on all of these operating systems.
3. Assuming the latest DirectX version from Microsoft doesn't fix the dinput.dll error you're receiving, look for a DirectX installation program on your game or application CD or DVD. Usually, if a game or other program utilizes DirectX, the software developers will include a copy of DirectX on the installation disc.
Sometimes, though not often, the DirectX version included on the disc is a better fit for the program than the latest version available online.
Uninstall the game or software program and then reinstall it again. Something might have happened to the program files that work with dinput.dll and a reinstall could do the trick.
Restore the dinput.dll file from the latest DirectX software package. If the above troubleshooting steps haven't worked to solve your dinput.dll error, try extracting the dinput.dll individually from the DirectX downloadable package.
4. Update the drivers for your video card. While it's not the most common solution, in some situations updating the drivers for the video card in your computer could correct this DirectX issue.
Here is a good link for DirectX info on how to download and install:
http://support.microsoft.com/kb/179113
Jun 04, 2012 | EA Sports Cricket 07 for Windows
Tip
D3dx9_37 is missing?
This is due to the fact that your Direct X 9 version is either out of date or just plain missing.
The d3dx9_37.dll file is one of many similar files contained in the DirectX software collection. Because DirectX is used by most Windows based games and advanced graphics programs these errors usually show up when using these programs.
To fix this it is as simple of downloading the latest version of DX9.
Click here to go to FileHippo and get the June 2010 version. Click on the green arrow to the right to start the download.
I've had many people ask me "how is this possible when I've just installed Windows Vista or even Windows 7." The simple answer is that when you install Windows Vista for example it ONLY installes Direct X10 components and when you install Windows 7 it ONLY installs DirectX 10 or 11. Therefore you will need to seperately download and install DirectX 9 in order to play games in DirectX 9 solve this problem.
If installing the latest version of DirectX 9 doesn't solve the problem then do the following:
  • Explore the game CD you are trying to use and find the DirectX 9 version the game or program came with. Install this version.
  • Uninstall the game or software and then re-install it. One of the files associated with d3dx9_37 may have been overwritten or deleted by accident.
  • You could try extracting the d3dx9_37 from the DirectX 9 package and placing it where it needs to be.
  • Re-install or update your graphics card drivers.
on Nov 14, 2010 | Computers & Internet
Does anybody have a link to any user instructions for Avermedia DVD EZMaker USB Gold
Should be under ,,avermedia ,,.com..or something like that,,,search ,,they have a website,,good luck
Dec 20, 2011 | Televison & Video
Capture device not recognized
this problem can be caused by many different things, I would recommend you try the following:
1, I would first uninstall the software and drivers for the stick and then clean the computers registry using a program such as the free for 30 days tune up utilities available from http://www.tune-up.com/products/tuneup-utilities/
2, Download the latest drivers from AverMedias website instead of using the ones provided on the CD
3, Make sure you have the latest drivers for your graphics card, updates are available from the graphics card manufacturer.
4, Try the stick in a different USB port
5, Defrag your harddrive
If after all this the stick does not work I would return it to the manufacturer and ask for a replacement to rule out that it is the stick and not your computer
Dec 16, 2008 | Avermedia AVerDVD EZMaker Video Capture
Is the AverDVD EZmaker PCI video capture card Vista-compatible? I am trying to capture video using newDVD, but I don't see anything in the video window?
My AVerTV program does not run properly. I have installed it properly but each time I click on the TV icon it runs for a few seconds and then it closes with a message that AverTV Media has encountered a propblem and needs to close. What can I do to fix the problem.
Sep 07, 2008 | Avermedia AVerDVD EZMaker Video Capture
Avermedia Technology AVer DVD EZMaker 7 C039 Signal Converter - Functions: Signal Logo
24 people viewed this question
Top Avermedia Technology Video Cameras Experts
Are you an Avermedia Technology Video Camera Expert? Answer questions, earn points and help others
