Question about Home Security
What battery does the doorbell use
Model 3301t doc is76 Carlon
I have a Carlon RC8233R plug in chime with multiple door bells and different chimes. The doorbells have started intermittently ringing without being pressed. Would you know the cause of this? Thanks
Hello Laurie DeLisi,
If you live in the NORTHERN Hemisphere...
my best guess would be RAIN-WATER...
Dismount the unit and bring it inside... Open it and look
for moisture...
Then look at the instructions and see if the BUTTONS
ARE SUITABLE FOR wet locations...
ELSE
You have a NEAR Neighbor... with conflicting radio signals
(just guessing here)
Carnac the Magnificent
Nov 28, 2017 | Carlon Home Security
How do I change the batteries in my Carlon RC8800R doorbell
Do you need to replace the batteries in the chime button or the receiver? To change the batteries on the doorbell (chime button) for most Carlon models, you need a ballpoint pen first to remove the chime button from the back. Press the pen point in the small round hole at the bottom of the button. Then gently push in on the tab. Finally rotate the chime button cover up and away from the back cover. Next take the ballpoint pen or a small screwdriver and place it in the slot below the top battery. Lift the battery up. Repeat this with the second battery. Then place the replacement CR2032 batteries into the battery compartment one at a time with the positive side up.
For the most of the wireless receivers, press the center of the brass tubes and lift those free to replace the 4 D cell batteries (2 behind each tube). A few models have a more obvious battery cover for a set of 4 AA cell batteries.
Many Carlon wireless chime manuals are available here: http://www.lamson-home.com/WirelessChimes.php . The direct link to the manual listed for the RC8800R is http://www.lamson-home.com/ProductSupport/WirelessChimes/RC3304_4300IM_3.06_v2.pdf .
I hope this helps.
Oct 09, 2016 | Carlon Home Security
How do I change the battery on the Door Push Button?
Easy....You'll need a very small screw driver. There's a small hole on one of the long ends (most are rectangular in shape). For the brand of door bell I have (Thomas and Betts/Carlon), you push in and downward with the screwdriver. This pushes out the bottom (back of doorbell button). In my case, there are (3) CR 2032 Button Cell batteries in a stacking position. As a quick side note -> If your wireless doorbell button does use button cell batteries. Look to Ebay to purchase them. You can get 6-10 batteries shipped to your front door cheaper. Rather than 3-4 batteries at a retail store + tax...Hopefully, I have lent you some assistance...Thanks for reading
Apr 25, 2015 | Carlon Wireless Doorbell system with...
How do i add a second switch to my rc8233r?
I would try Ebay first (or search the net for availability and prices). I bought CR2032 3V Button Cell (that are used in my Carlon door chime buttons) batteries. I got 10 for under $5. Carlon (Thomas & Betts) still makes a variety of door chimes and accessories. However, on their site, the prices are atrocious. But, I think that Thomas & Betts deals in bulk (as in dealing with retailers). Because they list their items in bulk price form. I personally have 5 T&B wireless door chimes. Hence, 4 of the buttons are in storage. Out of curiosity, I tried all of them. All 4 extra buttons rang all the door chimes. Caution, on the packages of the door "chimes" I purchased. There's a blurb on there that states the wireless buttons for the "door chimes" will not work with the "doorbells". If you have the packaging for the one you have. It will explain. I'm not positive, but it seems the variance is due to whether you use battery or electric powered models. Hope I was of assistance...Greg
Jul 20, 2014 | Carlon Wireless Doorbell system with...
Carlon door chime model RC8413
There is a tiny button on the top of the doorbell outside, and all you have to do it press it until you get to the desired chime!
Aug 11, 2012 | Carlon Wireless Doorbell system with...
Carlon RC8800R how to set chime for westminster crime
The Carlon RC8800R door chime, quicks chiming usally within two days of mounting the base unit interior wall. If I take down and re-arrange the 4-D size batteries in sometimes starts chiming again. Is the base unit just a "lemon"?
Nov 29, 2011 | Carlon Wireless Doorbell system with...
Home Security Logo
134 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
