Question about Canon SmartBase MP360 All-In-One InkJet Printer
Not printin clearly
I have a smartbase MP360 its not been in use for 18 months and now does not print clearly..i have done all the maintenence checks, changed the inkjets. Anyone have any ideas...
  • patch1322 May 25, 2009
    its printing smudgie lines
  • Jonathan Van Rensburg
    Jonathan Van Rensburg May 11, 2010
    Hi is there lines missing?
  • Canon Master
  • 365 Answers
Take out the head and cartridges.
Make a solution of 15-20% ammonia to warm (170 degree) water and soak head for 30-45 minutes.
Completely dry out head especially the contacts.
Now do a cleaning cycle then nozzle check.You should see some paterns printed.If faint clean again until you are satisfied
Posted on Aug 01, 2009
My Canon Smartbase MP360 will not print and shows 'put in cartridge' which I have done and it makes no difference.
sometimes a little bit of dried ink stops the flow of ink
use a cue tip and genty clean both the puter contacts
and the cartridge contacts then try again
after resetting do the head cleaning tht the machine can do for itself
this work most of the time
hope it help ps watch and dont let any fuzz get left behind
Aug 22, 2012 | Canon SmartBase MP360 All-In-One InkJet...
I keep getting a "wrong
Clean the print head/cartridge with Isopropol Alcohol (rubbing alcohol)and Q-Tips, The nozzles, the contacts and all the excess ink that had acummulated around the nozzles. The error message should clear.Run through all the maintenance checks and alignments. If this does not fix it, the print head needs to be replaced about $45-$60 from Canon.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 20, 2011 | Canon SmartBase MP730 All-In-One InkJet...
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
I have replaced the black but it still won't print
You have a clogged print head.Try with "cleaning" or "deep cleaning" test, you find it in "maintenance" menu.If not help you need to replace the print head.It's part number is QY6-0037.
Oct 09, 2009 | Canon Office Equipment & Supplies
I have a Smartbase MP360, and it will not print out anything, or even do a straight forward coping. I have put in new ink cartridges, and run the maintenance checks, but it has only achieved to print all...
I have not solved my problem, but I am not prepared to pay for your assistance. I will go to a stockist, to see if they are able to solve my problem free of charge.
Many Tahnks
Margaret Fitch
Sep 18, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Canon Smartbase MP360 showing error code ##336
It seems the home position sensor is out of whack or the mylar band behind the print cartridge carriage is missing or broken.
To find the mylar piece look for a clear 6mm x 460mm clear piece of plastic with black markings (like a gradient) on both sides.If you find it you can try and place it back by looking for an extended eyelet on both sides of the stell print carrier.
Most people in haste to change ink have the hand slip and it becomes dislodged.
Jun 17, 2009 | Canon SmartBase MP360 All-In-One InkJet...
Smartbase MP390 Printer - error ##345
canon smartbase mp390 error ##345 check printer can anyone help me
Nov 01, 2008 | Canon SmartBase MP390 All-In-One InkJet...
Canon smartbase mp730
Have you tried doing some maintenance like nozzle check,printing head alignment,clean the nozzles if not then try it by going into control panel - printers and faxes - where you see your mp730 right click and go to properties then click on the last tab which would be maintenance.Try those options if none worked then u might have to replace you print head and that should work
Nov 26, 2007 | Canon SmartBase MP730 All-In-One InkJet...
Open Questions:
See all Canon SmartBase MP360 All-In-One InkJet Printer Questions
Canon SmartBase MP360 All-In-One InkJet Printer Logo
128 people viewed this question
old marine
old marine
