Question about Moose Z900st Lcd Alarm Keypad Z900 St
Amseco 832t does not chime when closed - Moose Z900st Lcd Alarm Keypad Z900 St
How to disconnect the chiming noise and make it stop?
If you take out the chime unit the dome light will not work again. Replace the chime unit
Mar 23, 2015 | 1992 Pontiac Bonneville
How do I disconnect the warning chime?
Key in ignition chime ?
Saturn L-Series ?????? L what ? L100 ,L200 , L300
Audible Warnings
The body control module (BCM) will provide an audible warning for various events relating to the vehicle. The functions that provide an audible warning are the key in ignition, the lights on, the occupant restraint (seat belt) and the park brake.
Key in the Ignition Audible Chime
The BCM will provide an audible chime if the key is left in the ignition in either OFF or the accessory position with the driver's door open. The chime rate for this is 150 chimes per minute. The key in the ignition chime has a higher priority than the lights on chime.
Lights on Audible Chime
The BCM will provide an audible chime if the park lights are on and the driver's door is open. In addition, 1 or 2 other conditions exist. The key is out of the ignition, or the key is in the ignition in the OFF position, and has not been turned. The BCM will chime at a rate of 200 chimes per minute until the conditions are removed.
Occupant Restraint Audible Chime
The BCM will provide an audible chime based on the class II message received from the SDM if the driver's seat belt is not buckled when the ignition is turned to run or crank. The chime rate for this feature is 50 chimes per minute.
Park Brake Audible Chime
The BCM will provide an audible chime for park brake when the park brake is applied and the vehicle speed is higher that 3 mph. The chime rate for this feature is 200 chimes per minute.
You can't disconnect anything . The problem has to be fixed .
Audible Warnings (Chime)
Chime Rate Per Minute
150
200
Occupant (Seat Belt) Restraint Audible Chime
50
200
Content Theft Pre-Alarm Audible Chime
200
Telltale Chimes
The body control module (BCM) will provide 4 chimes for each telltale activation per ignition cycle, at a rate of 150 or 200 chimes per minute. The chimes are limited to 1 chime event per telltale for each ignition cycle. The power up telltale function will not activate the telltale chime function. If the telltale becomes active during a cycle then the chime will sound.
The following telltales will activate the chime function:
• Low Washer Fluid
• Change Oil Soon Indicator
• Brake Fluid Low
• Oil Pressure Low
• Coolant Temperature Hot
• Low Coolant Level
• Low Fuel Level
• Antilock Brake System
• Volts Light (Generator)
• Supplemental Inflatable Restraint System (Air Bag)
• Trunk or Hatch Ajar
Having the vehicle checked for DTC'S - diagnostic trouble code's in the BCM would be the first step in the diagnostic procedure .
DTC B2965
When the ignition key is seated in the ignition switch, the key-in-ignition switch contacts the close, grounding circuit 80. The body control module (BCM) monitors the state of the key-in-ignition switch, the state of the ignition switch (OFF, ACC, or RUN) and the driver's door to control the key-in-ignition chime.
Nov 28, 2017 | 2002 Saturn L-Series
TRYING TO FIX A DOOR CHIME ON A 2002 PONTIAC SUNFIRE. NEED TO LOCATE WHERE DOOR CHIME IS LOCATED ON THIS VEHICLE
In most vehicles the "chime" is located in the dash around where your 4 way flaser is. It could simply be the door switch also which is a little button that depresses when you close the door to open the circuit shutting the dome light and chime off. They are easy to change and inexpensive. Hope that helps.
Aug 05, 2011 | 2002 Pontiac Sunfire
99 new beetle- warning chimes not working
Have you checked the fuse box, it may be on an obscure circuit. check each and every fuse closely.
Hope this is of some help.
Apr 20, 2009 | 2001 Volkswagen Beetle
Warning chime continues to chime as I drive
My guess is a faulty switch at door for turning off interior lights/door closed, which is giving chime that door is still open
Dec 10, 2008 | 1997 Ford Mustang Cobra
Timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
Oct 04, 2008 | Watches
Moose Z900st Lcd Alarm Keypad Z900 St Logo
54 people viewed this question
Top Moose Home Security Experts
Lawrence Oravetz
Are you a Moose Home Security Expert? Answer questions, earn points and help others
